Asus ROG G752V Fan Replacement
    1. Asus ROG G752V Fan Replacement, Battery: step 1, image 1 of 2 Asus ROG G752V Fan Replacement, Battery: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Make sure you disconnect the charger before starting this guide.
      • Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
      Ask FixBot
    2. Asus ROG G752V Fan Replacement: step 2, image 1 of 2 Asus ROG G752V Fan Replacement: step 2, image 2 of 2
      • Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
      • There is one 5.2 mm screw under the rubber plug in the middle.
      Ask FixBot
    3. Asus ROG G752V Fan Replacement: step 3, image 1 of 1
      • Pull up the rubber seal and the service cover will come off.
      Ask FixBot
    4. Asus ROG G752V Fan Replacement: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
      Ask FixBot
    5. Asus ROG G752V Fan Replacement: step 5, image 1 of 1
      • Using your hands, pull the optical drive out.
      Ask FixBot
    6. Asus ROG G752V Fan Replacement: step 6, image 1 of 2 Asus ROG G752V Fan Replacement: step 6, image 2 of 2
      • Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
      • Start from the front side of the laptop and then continue to the side for easier access.
      Ask FixBot
    7. Asus ROG G752V Fan Replacement: step 7, image 1 of 2 Asus ROG G752V Fan Replacement: step 7, image 2 of 2
      • Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
      • Be gentle with the cover because there is a speaker wire attached to it.
      Ask FixBot
    8. Asus ROG G752V Fan Replacement: step 8, image 1 of 2 Asus ROG G752V Fan Replacement: step 8, image 2 of 2
      • Disconnect the speaker wire.
      Ask FixBot
    9. Asus ROG G752V Fan Replacement: step 9, image 1 of 2 Asus ROG G752V Fan Replacement: step 9, image 2 of 2
      • Slowly pull out the keyboard while lifting it about an inch.
      • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
      Ask FixBot
    10. Asus ROG G752V Fan Replacement: step 10, image 1 of 3 Asus ROG G752V Fan Replacement: step 10, image 2 of 3 Asus ROG G752V Fan Replacement: step 10, image 3 of 3
      • Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
      Ask FixBot
    11. Asus ROG G752V Fan Replacement: step 11, image 1 of 2 Asus ROG G752V Fan Replacement: step 11, image 2 of 2
      • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
      • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
      Ask FixBot
    12. Asus ROG G752V Fan Replacement: step 12, image 1 of 3 Asus ROG G752V Fan Replacement: step 12, image 2 of 3 Asus ROG G752V Fan Replacement: step 12, image 3 of 3
      • Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
      • Pull parallel to the motherboard, not straight up.
      Ask FixBot
    13. Asus ROG G752V Fan Replacement: step 13, image 1 of 3 Asus ROG G752V Fan Replacement: step 13, image 2 of 3 Asus ROG G752V Fan Replacement: step 13, image 3 of 3
      • Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
      • This will unlatch the screen from the laptop entirely.
      • Remove the screen.
      Ask FixBot
    14. Asus ROG G752V Fan Replacement: step 14, image 1 of 1
      • Remove the four 5.8 mm screws securing the battery to the laptop.
      Ask FixBot
    15. Asus ROG G752V Fan Replacement: step 15, image 1 of 1
      • Use your hands to remove the battery.
      • If you're having trouble, push down on the black plastic on the screen side of the battery. This should release the battery.
      Ask FixBot
    1. Asus ROG G752V Fan Replacement, Fan: step 16, image 1 of 2 Asus ROG G752V Fan Replacement, Fan: step 16, image 2 of 2
      • Unplug the fan-motherboard connection cable.
      Ask FixBot
    2. Asus ROG G752V Fan Replacement: step 17, image 1 of 3 Asus ROG G752V Fan Replacement: step 17, image 2 of 3 Asus ROG G752V Fan Replacement: step 17, image 3 of 3
      • Unscrew and remove the three 5.8mm screws on the small circuit board to the right of the right side fan with a Phillips #00 screwdriver.
      • Lift up the small circuit board covering the fan and put it aside.
      Ask FixBot
    3. Asus ROG G752V Fan Replacement: step 18, image 1 of 2 Asus ROG G752V Fan Replacement: step 18, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the three 5.2 mm screws that connect the fan to the motherboard.
      Ask FixBot
    4. Asus ROG G752V Fan Replacement: step 19, image 1 of 1
      • With your hands, slowly and carefully lift up the right side fan.
      Ask FixBot
    5. Asus ROG G752V Fan Replacement: step 20, image 1 of 2 Asus ROG G752V Fan Replacement: step 20, image 2 of 2
      • Carefully unlatch the left side fan cable from the motherboard.
      Ask FixBot
    6. Asus ROG G752V Fan Replacement: step 21, image 1 of 3 Asus ROG G752V Fan Replacement: step 21, image 2 of 3 Asus ROG G752V Fan Replacement: step 21, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the two 5.8mm screws that connect the left fan to the motherboard.
      Ask FixBot
    7. Asus ROG G752V Fan Replacement: step 22, image 1 of 2 Asus ROG G752V Fan Replacement: step 22, image 2 of 2
      • With your hands, carefully lift the left fan and unlatch the fan from the motherboard.
      Ask FixBot
5 other people completed this guide.
1 Guide Comment
Awesome! Epic guide thank you!
Citizen Gone - Reply Share
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 90
All Time: 3,762
