Asus ROG G751JT-DH72 RAM Replacement
    1. Asus ROG G751JT-DH72 RAM Replacement, RAM: step 1, image 1 of 2 Asus ROG G751JT-DH72 RAM Replacement, RAM: step 1, image 2 of 2
      • Lift up the rubber tab located in the upper-right corner of the backing plate.
      Ask FixBot
    2. Asus ROG G751JT-DH72 RAM Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
      Ask FixBot
    3. Asus ROG G751JT-DH72 RAM Replacement: step 3, image 1 of 1
      • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
      Ask FixBot
    4. Asus ROG G751JT-DH72 RAM Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 5mm screw on the right side.
      Ask FixBot
    5. Asus ROG G751JT-DH72 RAM Replacement: step 5, image 1 of 1
      • Pull out the optical drive to revel the screws holding the laptop cover.
      Ask FixBot
    6. Asus ROG G751JT-DH72 RAM Replacement: step 6, image 1 of 2 Asus ROG G751JT-DH72 RAM Replacement: step 6, image 2 of 2
      • Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
      Ask FixBot
    7. Asus ROG G751JT-DH72 RAM Replacement: step 7, image 1 of 1
      • Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
      Ask FixBot
    8. Asus ROG G751JT-DH72 RAM Replacement: step 8, image 1 of 1
      • Flip over the laptop and pry the 2 vent covers off.
      Ask FixBot
    9. Asus ROG G751JT-DH72 RAM Replacement: step 9, image 1 of 1
      • Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
      Ask FixBot
    10. Asus ROG G751JT-DH72 RAM Replacement: step 10, image 1 of 2 Asus ROG G751JT-DH72 RAM Replacement: step 10, image 2 of 2
      • Pry along the edges of the keyboard to lift it up.
      • Be careful not to damage the ribbon connectors.
      Ask FixBot
    11. Asus ROG G751JT-DH72 RAM Replacement: step 11, image 1 of 2 Asus ROG G751JT-DH72 RAM Replacement: step 11, image 2 of 2
      • Disconnect all 4 ribbon connectors with a tweezer.
      Ask FixBot
    12. Asus ROG G751JT-DH72 RAM Replacement: step 12, image 1 of 1
      • Carefully, pull on the side tabs to release the RAM card.
      Ask FixBot
Anum Haidari
558 Reputation
3 Guides authored
UC Davis, Team S7-G4, Lore Fall 2018 Member of UC Davis, Team S7-G4, Lore Fall 2018
UCD-LORE-F18S7G4
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 64
All Time: 1,709
