Asus ROG G751JT-DH72 HDD/SSD Replacement
    1. Asus ROG G751JT-DH72 HDD/SSD Replacement, HDD/SSD: step 1, image 1 of 1
      • Lift up the rubber tab located in the upper-right corner of the backing plate.
      Ask FixBot
    2. Asus ROG G751JT-DH72 HDD/SSD Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
      Ask FixBot
    3. Asus ROG G751JT-DH72 HDD/SSD Replacement: step 3, image 1 of 1
      • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
      Ask FixBot
    4. Asus ROG G751JT-DH72 HDD/SSD Replacement: step 4, image 1 of 1
      • Use a Phillips head screwdriver to remove the four 2.4 mm screws from the hard drive mount.
      • Remove the hard drive from the device.
      Ask FixBot
Anum Haidari
558 Reputation
3 Guides authored
UC Davis, Team S7-G4, Lore Fall 2018 Member of UC Davis, Team S7-G4, Lore Fall 2018
UCD-LORE-F18S7G4
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 30
All Time: 1,036
