Asus ROG G751JT-DH72 CD Drive Replacement
    1. Asus ROG G751JT-DH72 CD Drive  Replacement, CD drive: step 1, image 1 of 1
      • Lift up the rubber tab located in the upper-right corner of the backing plate.
      Ask FixBot
    2. Asus ROG G751JT-DH72 CD Drive  Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
      Ask FixBot
    3. Asus ROG G751JT-DH72 CD Drive  Replacement: step 3, image 1 of 1
      • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
      Ask FixBot
    4. Asus ROG G751JT-DH72 CD Drive  Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 5 mm screw.
      Ask FixBot
    5. Asus ROG G751JT-DH72 CD Drive  Replacement: step 5, image 1 of 1
      • Pull out the drive and remove it from the device.
      Ask FixBot
Anum Haidari
558 Reputation
3 Guides authored
UC Davis, Team S7-G4, Lore Fall 2018 Member of UC Davis, Team S7-G4, Lore Fall 2018
UCD-LORE-F18S7G4
2 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 58
All Time: 555
