Asus ROG G751JL-DS71 Monitor Replacement
    1. Asus ROG G751JL-DS71 Monitor Replacement, CD-ROM Player: step 1, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement, CD-ROM Player: step 1, image 2 of 2
      • Lift the rubber cover found on the bottom of the laptop.
      • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
      Ask FixBot
    2. Asus ROG G751JL-DS71 Monitor Replacement: step 2, image 1 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 2, image 2 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 2, image 3 of 3
      • Use the nylon spudger to remove the back center panel.
      Ask FixBot
    3. Asus ROG G751JL-DS71 Monitor Replacement: step 3, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement: step 3, image 2 of 2
      • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
      Ask FixBot
    4. Asus ROG G751JL-DS71 Monitor Replacement: step 4, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement: step 4, image 2 of 2
      • Pull out the optical drive found on the side of the laptop.
      Ask FixBot
    1. Asus ROG G751JL-DS71 Monitor Replacement, Top Rear Panel: step 5, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement, Top Rear Panel: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
      Ask FixBot
    2. Asus ROG G751JL-DS71 Monitor Replacement: step 6, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement: step 6, image 2 of 2
      • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
      Ask FixBot
    3. Asus ROG G751JL-DS71 Monitor Replacement: step 7, image 1 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 7, image 2 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 7, image 3 of 3
      • Use a nylon spudger to carefully pry the top back panel off.
      • While removing the top back panel, be careful not to break the four pin connector located underneath.
      • Disconnect the four-pin connector and remove the top back panel from the computer.
      Ask FixBot
    1. Asus ROG G751JL-DS71 Monitor Replacement, Keyboard: step 8, image 1 of 3 Asus ROG G751JL-DS71 Monitor Replacement, Keyboard: step 8, image 2 of 3 Asus ROG G751JL-DS71 Monitor Replacement, Keyboard: step 8, image 3 of 3
      • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
      • Lift away the metal housings from each side of the laptop.
      Ask FixBot
    2. Asus ROG G751JL-DS71 Monitor Replacement: step 9, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement: step 9, image 2 of 2
      • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
      • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
      Ask FixBot
    3. Asus ROG G751JL-DS71 Monitor Replacement: step 10, image 1 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 10, image 2 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 10, image 3 of 3
      • Use a plastic opening tool to pry the keyboard from the base of the laptop.
      • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
      Ask FixBot
    4. Asus ROG G751JL-DS71 Monitor Replacement: step 11, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement: step 11, image 2 of 2
      Buy
      • Use a pair of tweezers to undo each of the four ribbon connectors.
      • The keyboard is now completely disconnected from the laptop and you can remove it.
      Ask FixBot
    1. Asus ROG G751JL-DS71 Monitor Replacement, Monitor: step 12, image 1 of 2 Asus ROG G751JL-DS71 Monitor Replacement, Monitor: step 12, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully disconnect the pin connector.
      Ask FixBot
    2. Asus ROG G751JL-DS71 Monitor Replacement: step 13, image 1 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 13, image 2 of 3 Asus ROG G751JL-DS71 Monitor Replacement: step 13, image 3 of 3
      • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
      • The monitor is now free to be completely lifted off the laptop.
      Ask FixBot
Alex C Gonzalez
113 Reputation
1 Guide authored
Cal Poly, Team S16-G1, Banghart Winter 2018 Member of Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 39
Past 30 Days: 129
All Time: 1,490
