Asus ROG G751JL-DS71 Hard Drive Replacement
    1. Asus ROG G751JL-DS71 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Asus ROG G751JL-DS71 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Lift the rubber cover found on the bottom of the laptop.
      • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
      Ask FixBot
    2. Asus ROG G751JL-DS71 Hard Drive Replacement: step 2, image 1 of 3 Asus ROG G751JL-DS71 Hard Drive Replacement: step 2, image 2 of 3 Asus ROG G751JL-DS71 Hard Drive Replacement: step 2, image 3 of 3
      • Use the black nylon spudger to pry the back panel off the laptop.
      Ask FixBot
    3. Asus ROG G751JL-DS71 Hard Drive Replacement: step 3, image 1 of 3 Asus ROG G751JL-DS71 Hard Drive Replacement: step 3, image 2 of 3 Asus ROG G751JL-DS71 Hard Drive Replacement: step 3, image 3 of 3
      • Use a Phillips 1 Screwdriver to remove the four 2.4 mm screws securing the hard drive.
      • Use the black pull-tab located on the shell covering the hard drive, to lift the hard drive housing and pull the hard drive away from the connector.
      • To access the hard drive on the right side of the laptop, perform the same steps, but on hard drive casing to the right of the previous hard drive.
      Ask FixBot
2 other people completed this guide.
Vincent Guarino
190 Reputation
1 Guide authored
Cal Poly, Team S16-G1, Banghart Winter 2018 Member of Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 35
All Time: 948
