Asus ROG G751JL-DS71 Fan Replacement
    1. Asus ROG G751JL-DS71 Fan Replacement, Fan: step 1, image 1 of 2 Asus ROG G751JL-DS71 Fan Replacement, Fan: step 1, image 2 of 2
      • Lift the rubber cover found on the bottom of the laptop.
      • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
      Ask FixBot
    2. Asus ROG G751JL-DS71 Fan Replacement: step 2, image 1 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 2, image 2 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 2, image 3 of 3
      • Use the standard spudger to remove the back center panel.
      Ask FixBot
    3. Asus ROG G751JL-DS71 Fan Replacement: step 3, image 1 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 3, image 2 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 3, image 3 of 3
      • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
      Ask FixBot
    4. Asus ROG G751JL-DS71 Fan Replacement: step 4, image 1 of 2 Asus ROG G751JL-DS71 Fan Replacement: step 4, image 2 of 2
      • Pull out the optical drive found on the side of the laptop.
      Ask FixBot
    5. Asus ROG G751JL-DS71 Fan Replacement: step 5, image 1 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 5, image 2 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 5, image 3 of 3
      • Remove the screws holding the hard drives in place using a phillips #1 screwdriver.
      • Using the small flaps, remove the hard drives by hand.
      Ask FixBot
    6. Asus ROG G751JL-DS71 Fan Replacement: step 6, image 1 of 2 Asus ROG G751JL-DS71 Fan Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
      Ask FixBot
    7. Asus ROG G751JL-DS71 Fan Replacement: step 7, image 1 of 2 Asus ROG G751JL-DS71 Fan Replacement: step 7, image 2 of 2
      • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
      Ask FixBot
    8. Asus ROG G751JL-DS71 Fan Replacement: step 8, image 1 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 8, image 2 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 8, image 3 of 3
      • Use a metal spudger to carefully pry the top back panel off.
      • While removing the top back panel, be careful not to break the four pin connector located underneath.
      • Disconnect the four-pin connector and remove the top back panel from the computer.
      Ask FixBot
    9. Asus ROG G751JL-DS71 Fan Replacement: step 9, image 1 of 1
      • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
      Ask FixBot
    10. Asus ROG G751JL-DS71 Fan Replacement: step 10, image 1 of 1
      • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
      Ask FixBot
    11. Asus ROG G751JL-DS71 Fan Replacement: step 11, image 1 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 11, image 2 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 11, image 3 of 3
      • Use a metal opening tool to pry the keyboard from the base of the laptop.
      • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
      Ask FixBot
    12. Asus ROG G751JL-DS71 Fan Replacement: step 12, image 1 of 2 Asus ROG G751JL-DS71 Fan Replacement: step 12, image 2 of 2
      • Use a pair of tweezers to undo each of the four ribbon connectors.
      • The keyboard is now completely disconnected from the laptop and you can remove it.
      Ask FixBot
    13. Asus ROG G751JL-DS71 Fan Replacement: step 13, image 1 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 13, image 2 of 3 Asus ROG G751JL-DS71 Fan Replacement: step 13, image 3 of 3
      • Disconnect the four-pin connectors from each fan and remove them
      • The fans are now completely disconnected from the laptop and you can remove them
      Ask FixBot
Ashley Twigg
237 Reputation
1 Guide authored
IUPUI, Team S8-G8, Wilson Spring 2019 Member of IUPUI, Team S8-G8, Wilson Spring 2019
IUPUI-WILSON-S19S8G8
4 Members
36 Guides authored
1 Guide Comment
i was wondering if i can swap the bottom case of g751jl with bottom case of g751jy? thanks a ton
Avkash - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 1,353
