Asus ROG G751JL-DS71 Central Processing Unit Replacement
  1. Asus ROG G751JL-DS71 Central Processing Unit Replacement, Central Processing Unit: step 1, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement, Central Processing Unit: step 1, image 2 of 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver
    Ask FixBot
  2. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 2, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 2, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 2, image 3 of 3
    • Use the standard spudger to remove the back center panel.
    Ask FixBot
  3. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 3, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 3, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 3, image 3 of 3
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
    Ask FixBot
  4. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 4, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 4, image 2 of 2
    • Pull out the optical drive found on the side of the laptop.
    Ask FixBot
  5. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 5, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 5, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 5, image 3 of 3
    • Remove the screws holding the hard drives in place using a phillips #1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
    Ask FixBot
  6. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 6, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
    Ask FixBot
  7. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 7, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 7, image 2 of 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
    Ask FixBot
  8. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 8, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 8, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 8, image 3 of 3
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
    Ask FixBot
  9. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 9, image 1 of 1
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    Ask FixBot
  10. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 10, image 1 of 1
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    Ask FixBot
  11. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 11, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 11, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 11, image 3 of 3
    • Use a metal opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
    Ask FixBot
  12. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 12, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 12, image 2 of 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
    Ask FixBot
  13. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 13, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 13, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 13, image 3 of 3
    • Remove the ribbon that connect the fans.
    Ask FixBot
  14. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 14, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 14, image 2 of 2
    • Remove the ribbon cables connected to the motherboard.
    Ask FixBot
  15. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 15, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 15, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 15, image 3 of 3
    • Remove the screws holding in the motherboard using a Phillips 0 screwdriver.
    • Remove the motherboard by hand. Be careful as the radiators for the fans are connected underneath the screen.
    Ask FixBot
  16. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 16, image 1 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 16, image 2 of 3 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 16, image 3 of 3
    • Remove the heat sink by hand. Be careful not to get thermal paste on your hand
    Ask FixBot
  17. Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 17, image 1 of 2 Asus ROG G751JL-DS71 Central Processing Unit Replacement: step 17, image 2 of 2
    • The CPU can then be removed with a regular spudger.
    • The CPU is now completely disconnected from the laptop and you can remove it.
    Ask FixBot
Justin Keathley
265 Reputation
1 Guide authored
IUPUI, Team S8-G8, Wilson Spring 2019 Member of IUPUI, Team S8-G8, Wilson Spring 2019
IUPUI-WILSON-S19S8G8
4 Members
3 Guides authored
2 Guide Comments
Hi Justin, if I were to remove the motherboard and insert a new one using your procedure would I have to change anything in the bios or will just a physical switch do the thing.
kikiluthra - Reply Share
I was following this guide normally but then I saw the last step... are you f***ing kidding me?! You DO NOT PRY OFF that chip!! It's a BGA connection and you WILL destroy it. If you need your CPU or GPU replaced, either buy a new motherboard or seek a professional's service that replaces chips like that. But yikes, an iFixit guide that's pretty coherent yet the last step implies removing the chip and damaging it... I must be hallucinating. If anyone did mindlessly follow this guide without prior experience... you have my deepest condolences.
k24a1 - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,390
