Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement
    1. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement, Back Panel: step 1, image 1 of 1
      • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
      Ask FixBot
    2. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 2, image 1 of 3 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 2, image 2 of 3 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 2, image 3 of 3
      • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
      • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
      • Place a spudger beneath the back panel and pry it away from the laptop.
      Ask FixBot
    1. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement, Display Assembly: step 3, image 1 of 2 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement, Display Assembly: step 3, image 2 of 2
      • Remove all 5mm Phillips #00 screws from the back cover.
      Ask FixBot
    2. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 4, image 1 of 2 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 4, image 2 of 2
      • Use a spudger to pry the disc drive out of the laptop.
      Ask FixBot
    3. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 5, image 1 of 3 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 5, image 2 of 3 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 5, image 3 of 3
      • Open the laptop and turn it so that the ASUS logo is facing you.
      • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
      • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
      Ask FixBot
    4. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 6, image 1 of 3 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 6, image 2 of 3 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 6, image 3 of 3
      • Remove the 5mm Phillips #00 screws.
      • Lift up the silver hinge brackets on each side of the laptop.
      Ask FixBot
    5. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 7, image 1 of 2 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement: step 7, image 2 of 2
      • Remove the 5mm Phillips #00 screws from the hinges.
      • Detach the ribbon cable and remove the display assembly from the laptop.
      Ask FixBot
    1. Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement, Keyboard Assembly: step 8, image 1 of 2 Asus ROG G751JL-BSI7T28 Keyboard Assembly Replacement, Keyboard Assembly: step 8, image 2 of 2
      • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
      • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
      • Remove the keyboard from the laptop.
      Ask FixBot
Kristen Gismondi
108,485 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
77,882 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 39
All Time: 1,107
