Asus ROG G751JL-BB17T29 RAM Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
Past 7 Days:
26
Past 30 Days:
108
All Time:
2,667
Comments: 6
6 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach the user how to safely access the RAM sticks without damaging them or the surrounding components.
Tools
    1. Asus ROG G751JL-BB17T29 RAM Replacement, Remove the RAM access door: step 1, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement, Remove the RAM access door: step 1, image 2 of 2
      • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
      Ask FixBot
    2. Asus ROG G751JL-BB17T29 RAM Replacement: step 2, image 1 of 1
      • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
      • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
      Ask FixBot
    3. Asus ROG G751JL-BB17T29 RAM Replacement: step 3, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement: step 3, image 2 of 2
      • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
      • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
      Ask FixBot
    4. Asus ROG G751JL-BB17T29 RAM Replacement: step 4, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 4, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 4, image 3 of 3
      • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
      • Pry the door up to release the clips closest to the pick.
      • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
      Ask FixBot
    5. Asus ROG G751JL-BB17T29 RAM Replacement: step 5, image 1 of 1
      • Remove the RAM access door.
      Ask FixBot
    1. Asus ROG G751JL-BB17T29 RAM Replacement, Remove the optical drive: step 6, image 1 of 1
      • Remove the 5.2 mm Phillips #00 screw securing the optical drive.
      Ask FixBot
    2. Asus ROG G751JL-BB17T29 RAM Replacement: step 7, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 7, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 7, image 3 of 3
      • Insert an opening tool into the gap between the optical drive and the laptop.
      • Pry the optical drive straight out of the laptop.
      • Remove the optical drive.
      Ask FixBot
    1. Asus ROG G751JL-BB17T29 RAM Replacement, Remove the case screws: step 8, image 1 of 1
      • Use the point of a spudger to pry out eleven rubber plugs covering the screws on the bottom of the laptop.
      • Some plugs have a hole or notch into which you can insert the point of a spudger to more easily pry out the plugs.
      Ask FixBot
    2. Asus ROG G751JL-BB17T29 RAM Replacement: step 9, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement: step 9, image 2 of 2
      • Remove 18 Phillips #00 screws of the following lengths:
      • Eight 8.8 mm screws
      • Seven 5.2 mm screws
      • Three screws
      Ask FixBot
    3. Asus ROG G751JL-BB17T29 RAM Replacement, Remove the battery cover: step 10, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement, Remove the battery cover: step 10, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement, Remove the battery cover: step 10, image 3 of 3
      • Flip the laptop right-side up.
      • Use an opening pick to pry the left and right edges of the battery cover away from the laptop enough that you can grip the cover with your fingers.
      Ask FixBot
    4. Asus ROG G751JL-BB17T29 RAM Replacement: step 11, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement: step 11, image 2 of 2
      • Lift the battery cover straight up from the laptop.
      • Do not try to completely remove the cover yet, it is still tethered by a speaker cable.
      Ask FixBot
    5. Asus ROG G751JL-BB17T29 RAM Replacement, Disconnect the speaker cable: step 12, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement, Disconnect the speaker cable: step 12, image 2 of 2
      • Pull the speaker connectors straight away from each other to disconnect the speaker cable.
      • Make sure the speaker cable is out of the way before you reinstall the battery cover.
      Ask FixBot
    6. Asus ROG G751JL-BB17T29 RAM Replacement, Remove the upper case assembly: step 13, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement, Remove the upper case assembly: step 13, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement, Remove the upper case assembly: step 13, image 3 of 3
      • Open the laptop's display to a 90° angle.
      • Use a spudger to pry against one of the screw tabs on the back of the upper case assembly.
      • Make sure to pry as close as possible to the base of the tab to avoid damaging the tab.
      • Repeat this procedure with the other tab.
      • The upper case assembly is held in place by small clips around its edges. In this step, pry each tab up until you feel the nearest clips release.
      Ask FixBot
    7. Asus ROG G751JL-BB17T29 RAM Replacement: step 14, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement: step 14, image 2 of 2
      • Insert the flat end of a spudger in the gap between the laptop and the upper case assembly, near the display.
      • If there's not a big enough gap, repeat the previous step until you have space to insert the spudger.
      Ask FixBot
    8. Asus ROG G751JL-BB17T29 RAM Replacement: step 15, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 15, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 15, image 3 of 3
      • Slide the spudger along each edge of the upper case assembly, prying and releasing clips as you go.
      Ask FixBot
    9. Asus ROG G751JL-BB17T29 RAM Replacement: step 16, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 16, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 16, image 3 of 3
      • When all the clips securing the upper case assembly have been released, lift the assembly slightly and slide it down, away from the display, about an inch.
      • Do not attempt to remove the assembly yet. It is still attached to the laptop by four cables.
      Ask FixBot
    10. Asus ROG G751JL-BB17T29 RAM Replacement: step 17, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 17, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 17, image 3 of 3
      • Use the tip of a spudger to flip up the small locking flap of the keyboard backlight cable ZIF connector.
      • Be sure to pry up on the hinged flap, not the connector socket.
      • Gently pull the cable out of its socket.
      Ask FixBot
    11. Asus ROG G751JL-BB17T29 RAM Replacement: step 18, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 18, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Replacement: step 18, image 3 of 3
      • Repeat the previous step for the keyboard, trackpad buttons, and trackpad cables held in place by ZIF connectors.
      Ask FixBot
    12. Asus ROG G751JL-BB17T29 RAM Replacement: step 19, image 1 of 1
      • Remove the upper case assembly.
      Ask FixBot
    1. Asus ROG G751JL-BB17T29 RAM Replacement, Disconnect the battery: step 20, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement, Disconnect the battery: step 20, image 2 of 2
      • Pull the battery cable away from the connector in the same direction as the individual wires are running to disconnect the battery.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Ask FixBot
    1. Asus ROG G751JL-BB17T29 RAM Replacement, RAM: step 21, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Replacement, RAM: step 21, image 2 of 2
      • Pull tabs on the left and right side of the RAM stick outward to release RAM.
      Ask FixBot
Kristofer Cesaroni
986 Reputation
8 Guides authored
USF Tampa, Team 2-1, Sullivan Fall 2016 Member of USF Tampa, Team 2-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G1
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 108
All Time: 2,667
