Asus ROG G751JL-BB17T29 Hard Drive Replacement
    1. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: step 1, image 1 of 2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: step 1, image 2 of 2
      • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
      Ask FixBot
    2. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 2, image 1 of 1
      • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
      • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
      Ask FixBot
    3. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 3, image 1 of 2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 3, image 2 of 2
      • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
      • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
      Ask FixBot
    4. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 4, image 1 of 3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 4, image 2 of 3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 4, image 3 of 3
      • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
      • Pry the door up to release the clips closest to the pick.
      • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
      Ask FixBot
    5. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 5, image 1 of 1
      • Remove the RAM access door.
      Ask FixBot
    1. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: step 6, image 1 of 2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: step 6, image 2 of 2
      • Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
      • Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
      Ask FixBot
    2. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 7, image 1 of 3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 7, image 2 of 3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: step 7, image 3 of 3
      • Remove the four 2.4 mm screws securing the right hard drive housing with a Phillips screwdriver.
      Ask FixBot
Kyle Miller
713 Reputation
3 Guides authored
USF Tampa, Team 2-1, Sullivan Fall 2016 Member of USF Tampa, Team 2-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G1
4 Members
132 Guides authored
1 Guide Comment
Dose the Asus ROG G751JL have any m.2 port in there anywhere? And what is the maximum capacity of SSD use in the Asus ROG G751JL?
shohebulalam - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 44
All Time: 6,564
