Asus ROG G56JK Fan Replacement
    1. Asus ROG G56JK Fan Replacement, Battery: step 1, image 1 of 2 Asus ROG G56JK Fan Replacement, Battery: step 1, image 2 of 2
      • Push the slider to the opposite side, while pulling out the battery.
      • Remove the battery from the device.
      Ask FixBot
    1. Asus ROG G56JK Fan Replacement, Hard Drive: step 2, image 1 of 1
      • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
      • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
      Ask FixBot
    2. Asus ROG G56JK Fan Replacement: step 3, image 1 of 1
      • Slide the hard drive to left and remove it from the device.
      Ask FixBot
    1. Asus ROG G56JK Fan Replacement, Back Panel: step 4, image 1 of 1
      • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Asus ROG G56JK Fan Replacement: step 5, image 1 of 1
      • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
      • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
      Ask FixBot
    1. Asus ROG G56JK Fan Replacement, Fan: step 6, image 1 of 2 Asus ROG G56JK Fan Replacement, Fan: step 6, image 2 of 2
      • Unplug the red and yellow wires from the port in the motherboard.
      • Lightly pull on the red and yellow wires to release.
      Ask FixBot
    2. Asus ROG G56JK Fan Replacement: step 7, image 1 of 1
      • Remove the 5mm screw.
      • Remove the 4mm screw.
      Ask FixBot
    3. Asus ROG G56JK Fan Replacement: step 8, image 1 of 1
      • The fan is glued to the black box that it is inside of. When pulling the fan out, you may experience a small amount of tearing of the black box.
      • Gently pull the fan out of the black box.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 69
All Time: 2,349
