Asus ROG G53SW-XT1 Optical Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
63
All Time:
612
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the optical drive in the ASUS ROG G53SW-XT1.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Asus ROG G53SW-XT1 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Unplug the power cable and flip the computer over.
      Ask FixBot
    2. Asus ROG G53SW-XT1 Optical Drive Replacement: step 2, image 1 of 1
      • Unlock the battery by pushing the switch to the right.
      Ask FixBot
    3. Asus ROG G53SW-XT1 Optical Drive Replacement: step 3, image 1 of 2 Asus ROG G53SW-XT1 Optical Drive Replacement: step 3, image 2 of 2
      • Push and hold the left switch, then pull the battery out.
      Ask FixBot
    1. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: step 4, image 1 of 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: step 4, image 2 of 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: step 4, image 3 of 3
      • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
      Ask FixBot
    2. Asus ROG G53SW-XT1 Optical Drive Replacement: step 5, image 1 of 3 Asus ROG G53SW-XT1 Optical Drive Replacement: step 5, image 2 of 3 Asus ROG G53SW-XT1 Optical Drive Replacement: step 5, image 3 of 3
      • Disconnect the keyboard ribbon cables from the motherboard.
      Ask FixBot
    1. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: step 6, image 1 of 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: step 6, image 2 of 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: step 6, image 3 of 3
      • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
      Ask FixBot
    2. Asus ROG G53SW-XT1 Optical Drive Replacement: step 7, image 1 of 1
      • Remove the fourteen Phillips #0 screws.
      Ask FixBot
    3. Asus ROG G53SW-XT1 Optical Drive Replacement: step 8, image 1 of 2 Asus ROG G53SW-XT1 Optical Drive Replacement: step 8, image 2 of 2
      • Flip the laptop over and pull off the bottom cover.
      Ask FixBot
    1. Asus ROG G53SW-XT1 Optical Drive Replacement, Optical Drive: step 9, image 1 of 1
      • Remove the single 7mm Phillips #0 screw holding the hard drive in place.
      Ask FixBot
    2. Asus ROG G53SW-XT1 Optical Drive Replacement: step 10, image 1 of 2 Asus ROG G53SW-XT1 Optical Drive Replacement: step 10, image 2 of 2
      • Slide the hard drive out of the casing.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 63
All Time: 612
