Asus ROG G20CB CPU Cooler Replacement
  1. Asus ROG G20CB CPU Cooler Replacement, Fan: step 1, image 1 of 2 Asus ROG G20CB CPU Cooler Replacement, Fan: step 1, image 2 of 2
    • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
    Ask FixBot
  2. Asus ROG G20CB CPU Cooler Replacement: step 2, image 1 of 1
    • Slide the front panel to the left and lift gently.
    • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
    Ask FixBot
  3. Asus ROG G20CB CPU Cooler Replacement: step 3, image 1 of 1
    • Disconnect the cable carefully by pulling gently on both sides of the connector.
    Ask FixBot
  4. Asus ROG G20CB CPU Cooler Replacement: step 4, image 1 of 1
    • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
    • The fans are connected by a thin cable, be gentle when removing tray.
    Ask FixBot
  5. Asus ROG G20CB CPU Cooler Replacement: step 5, image 1 of 1
    • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
    Ask FixBot
  6. Asus ROG G20CB CPU Cooler Replacement: step 6, image 1 of 1
    • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
    Ask FixBot
  7. Asus ROG G20CB CPU Cooler Replacement, CPU Cooler: step 7, image 1 of 1
    • Remove the 4.6 mm Phillips screw that secures the optical drive.
    Ask FixBot
  8. Asus ROG G20CB CPU Cooler Replacement: step 8, image 1 of 1
    • Push the optical drive out of the chassis.
    Ask FixBot
  9. Asus ROG G20CB CPU Cooler Replacement: step 9, image 1 of 1
    • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
    • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
    Ask FixBot
  10. Asus ROG G20CB CPU Cooler Replacement: step 10, image 1 of 1
    • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
    • Lift the CPU cooler out of the system.
    • Be sure to apply fresh thermal paste before reinstalling a cooler.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
AdamGadd
349 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 262
