Asus ROG Claymore II Battery Replacement
    1. Asus ROG Claymore II Battery Replacement, Removing the keys: step 1, image 1 of 3 Asus ROG Claymore II Battery Replacement, Removing the keys: step 1, image 2 of 3 Asus ROG Claymore II Battery Replacement, Removing the keys: step 1, image 3 of 3
      • Start by using the Key cap remover to remove all keys from their key slots, be extremely careful because the keys are only put in place by 4 tiny plastic pins. Any bending will break them. Always pull the keys perpendicular to the keyboard.
      • Some keys need to be carefully pulled harder due to being slotted inside the keyboard in the iron supports. The "space" key is advisable to be pulled with both hands each side. As well as the "enter" key and the right "Shift" key.
      Ask FixBot
    2. Asus ROG Claymore II Battery Replacement, Locating and removing the screws: step 2, image 1 of 2 Asus ROG Claymore II Battery Replacement, Locating and removing the screws: step 2, image 2 of 2
      • Locate the screws on the keyboard.
      • With the Philips #00 screw driver, unscrew all of them.
      Ask FixBot
    3. Asus ROG Claymore II Battery Replacement, Separating the key board: step 3, image 1 of 2 Asus ROG Claymore II Battery Replacement, Separating the key board: step 3, image 2 of 2
      • Remove the magnetic left side protector of the keyboard. If you don't have the num pad part, procede to remove the right one as the left one.
      • The Keyboard will open on the bottom as shown on the photos. If not use the spudger to open it (very easy)
      • Don't open it very wide because you will have some wires to unplug first, just open it a bit so you can locate them
      Ask FixBot
    4. Asus ROG Claymore II Battery Replacement, Removing the contact wires: step 4, image 1 of 3 Asus ROG Claymore II Battery Replacement, Removing the contact wires: step 4, image 2 of 3 Asus ROG Claymore II Battery Replacement, Removing the contact wires: step 4, image 3 of 3
      • Each side will have, on the front of the keyboard, wires that connect to the sides. Locate them.
      • Using tweezers you can disconnect them from the sides. No need to disconnect them from the key board on the top since we don't need to work on it.
      • You will then be able to pull a bit gently the top part and separate it from the bottom, viewing the battery case and a small board that controls the connections on the back.
      Ask FixBot
    5. Asus ROG Claymore II Battery Replacement, Removing the battery container and small board: step 5, image 1 of 3 Asus ROG Claymore II Battery Replacement, Removing the battery container and small board: step 5, image 2 of 3 Asus ROG Claymore II Battery Replacement, Removing the battery container and small board: step 5, image 3 of 3
      • Locate the screws that lock the battery and the small board in place.
      • Unscrew them all and slowly lift the battery and the board at the same time (they are connected)
      Ask FixBot
    6. Asus ROG Claymore II Battery Replacement, Disconnecting the battery case: step 6, image 1 of 3 Asus ROG Claymore II Battery Replacement, Disconnecting the battery case: step 6, image 2 of 3 Asus ROG Claymore II Battery Replacement, Disconnecting the battery case: step 6, image 3 of 3
      • Turn the battery case and the small board upside down, remove the battery contact with the help of the spudger.
      • The battery case has 2 isolating strips in each side of the batery connector. You can either take those and apply later, or just like in my case, that I didn't had any at the moment, I decided to cut them with a box cutter.
      Ask FixBot
    7. Asus ROG Claymore II Battery Replacement, Removing the old battery: step 7, image 1 of 3 Asus ROG Claymore II Battery Replacement, Removing the old battery: step 7, image 2 of 3 Asus ROG Claymore II Battery Replacement, Removing the old battery: step 7, image 3 of 3
      • Pry open the case releasing the bottom where the battery is. Remember to release the isolating strips.
      • The battery is glued with adhesive to the bottom of the case. You'll have to apply some pressure to lift it up from the case.
      • Warning: remember this is a battery, any cuts, damage or punctures might cause the battery to ignite or even explode. So proceed with extreme caution on this step!
      Ask FixBot
    8. Asus ROG Claymore II Battery Replacement, Applying the new battery: step 8, image 1 of 3 Asus ROG Claymore II Battery Replacement, Applying the new battery: step 8, image 2 of 3 Asus ROG Claymore II Battery Replacement, Applying the new battery: step 8, image 3 of 3
      • Place the new battery in the battery case accordingly to the orientation of the opening for the connector and the small board socket.
      • Close the battery case and do not forget to re-apply the isolating tape.
      • Connect the battery to the small board, making some pressure on the connector.
      Ask FixBot
5 other people completed this guide.
Filipe Bento
308 Reputation
1 Guide authored
5 Guide Comments
i put anew batery but does not charge over 43%. that &&^&^$^ aliexpress
jamal - Reply Share
Mine has been charging to 100%. I wonder if yours came defective? I know it's a lot of trouble but maybe take it out and send it to seller. Ask a refund?
OR with the reference buy form other store?
Filipe Bento - Reply Share
Hi, my keyboard battery is swollen and I can't find the replacement battery you shared.
cagan ali - Reply Share
Gosh my keyboard just got broken rn, as in rn. Got sucked into rabbit hole found out the battery was the issue, touch the back of my claymore 2 and it has bulge.
found this on web: https://rog-forum.asus.com/t5/gaming-key...
Apparently this "Original Battery C11P1707 for Asus Zenfone Max m1 ZB555KL" fits and works for claymore 2
Danniel Belano - Reply Share
Yes the Asus Zenfone Max m1 ZB555KL battery works on the keyboard, plus the connector to the MB is the same.
Past 24 Hours: 14
Past 7 Days: 128
Past 30 Days: 510
All Time: 7,488
