Asus ROG Ally Macro Buttons Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
11
Past 7 Days:
35
Past 30 Days:
173
All Time:
2,472
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace or upgrade one or both the M1 and M2 macro buttons on your Asus ROG Ally.
Parts
Tools
    1. Asus ROG Ally Macro Buttons Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Asus ROG Ally Macro Buttons Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Asus ROG Ally Macro Buttons Replacement, Prepare your device for disassembly: step 1, image 3 of 3
      • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Completely power off your device and unplug all cables.
      • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
      Ask FixBot
    1. Asus ROG Ally Macro Buttons Replacement, Unfasten the back cover: step 2, image 1 of 2 Asus ROG Ally Macro Buttons Replacement, Unfasten the back cover: step 2, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
      • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
      • Don't try to remove this screw.
      Ask FixBot
    2. Asus ROG Ally Macro Buttons Replacement, Insert an opening pick: step 3, image 1 of 3 Asus ROG Ally Macro Buttons Replacement, Insert an opening pick: step 3, image 2 of 3 Asus ROG Ally Macro Buttons Replacement, Insert an opening pick: step 3, image 3 of 3
      • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
      • Angle the pick upward and push it under the back cover.
      Ask FixBot
    3. Asus ROG Ally Macro Buttons Replacement, Release the back cover's clips: step 4, image 1 of 3 Asus ROG Ally Macro Buttons Replacement, Release the back cover's clips: step 4, image 2 of 3 Asus ROG Ally Macro Buttons Replacement, Release the back cover's clips: step 4, image 3 of 3
      • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
      • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
      • Keep the pick at an upward angle under the back cover to help release the clips.
      Ask FixBot
    4. Asus ROG Ally Macro Buttons Replacement, Remove the back cover: step 5, image 1 of 3 Asus ROG Ally Macro Buttons Replacement, Remove the back cover: step 5, image 2 of 3 Asus ROG Ally Macro Buttons Replacement, Remove the back cover: step 5, image 3 of 3
      • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
      • Remove the back cover.
      • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
      Ask FixBot
    1. Asus ROG Ally Macro Buttons Replacement, Unfasten the macro buttons: step 6, image 1 of 2 Asus ROG Ally Macro Buttons Replacement, Unfasten the macro buttons: step 6, image 2 of 2
      • When removing the screws, be careful not to lose the springs under them. They can easily eject!
      • Use a Phillips #000 screwdriver to remove the 2.9 mm‑long screw securing each macro button (two total).
      Ask FixBot
    2. Asus ROG Ally Macro Buttons Replacement, Remove the springs: step 7, image 1 of 3 Asus ROG Ally Macro Buttons Replacement, Remove the springs: step 7, image 2 of 3 Asus ROG Ally Macro Buttons Replacement, Remove the springs: step 7, image 3 of 3
      Buy
      • Use tweezers or your fingers to remove the springs from their screw posts.
      Ask FixBot
    3. Asus ROG Ally Macro Buttons Replacement, Unclip the macro button: step 8, image 1 of 3 Asus ROG Ally Macro Buttons Replacement, Unclip the macro button: step 8, image 2 of 3 Asus ROG Ally Macro Buttons Replacement, Unclip the macro button: step 8, image 3 of 3
      • Two rectangular clips secure the macro buttons to the back cover.
      • Use the flat end of a spudger or your fingers to push in the clips securing one of the macro buttons.
      Ask FixBot
    4. Asus ROG Ally Macro Buttons Replacement, Remove the macro button: step 9, image 1 of 2 Asus ROG Ally Macro Buttons Replacement, Remove the macro button: step 9, image 2 of 2
      • Remove the macro button.
      Ask FixBot
    5. Asus ROG Ally Macro Buttons Replacement, Remove the other macro button: step 10, image 1 of 2 Asus ROG Ally Macro Buttons Replacement, Remove the other macro button: step 10, image 2 of 2
      • Repeat the last two steps to unclip and remove the other macro button.
      • During reassembly, firmly push the macro buttons into place to engage their clips. You should feel the clips click as they engage.
      Ask FixBot
Spencer Day
208,436 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,955 Guides authored
1 Guide Comment
One of the screws got damaged, i do not know how its it called or how i can find it. If you have that information I would appreciate it.
Damian Moreno - Reply Share
Past 24 Hours: 11
Past 7 Days: 35
Past 30 Days: 173
All Time: 2,472
