Asus ROG Ally Left Thumbstick Replacement
    1. Asus ROG Ally Left Thumbstick Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Prepare your device for disassembly: step 1, image 3 of 3
      • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Completely power off your device and unplug all cables.
      • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
      Ask FixBot
    1. Asus ROG Ally Left Thumbstick Replacement, Unfasten the back cover: step 2, image 1 of 2 Asus ROG Ally Left Thumbstick Replacement, Unfasten the back cover: step 2, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
      • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
      • Don't try to remove this screw.
      Ask FixBot
    2. Asus ROG Ally Left Thumbstick Replacement, Insert an opening pick: step 3, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Insert an opening pick: step 3, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Insert an opening pick: step 3, image 3 of 3
      • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
      • Angle the pick upward and push it under the back cover.
      Ask FixBot
    3. Asus ROG Ally Left Thumbstick Replacement, Release the back cover's clips: step 4, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Release the back cover's clips: step 4, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Release the back cover's clips: step 4, image 3 of 3
      • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
      • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
      • Keep the pick at an upward angle under the back cover to help release the clips.
      Ask FixBot
    4. Asus ROG Ally Left Thumbstick Replacement, Remove the back cover: step 5, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Remove the back cover: step 5, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Remove the back cover: step 5, image 3 of 3
      • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
      • Remove the back cover.
      • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
      Ask FixBot
    1. Asus ROG Ally Left Thumbstick Replacement, Remove the plastic cover: step 6, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Remove the plastic cover: step 6, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Remove the plastic cover: step 6, image 3 of 3
      • Use your fingers to peel up and remove the black plastic cover between the fans.
      • Put the cover aside—you'll use it during reassembly.
      Ask FixBot
    2. Asus ROG Ally Left Thumbstick Replacement, Unlatch the locking bar: step 7, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Unlatch the locking bar: step 7, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Unlatch the locking bar: step 7, image 3 of 3
      • A metal locking bar secures the top edge of the battery connector
      • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
      Ask FixBot
    3. Asus ROG Ally Left Thumbstick Replacement, Disconnect the battery: step 8, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the battery: step 8, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the battery: step 8, image 3 of 3
      • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
      • Insert the flat end of a spudger under the center of the battery connector.
      • Lift the connector straight up and out of its socket to disconnect the battery.
      • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
      Ask FixBot
    1. Asus ROG Ally Left Thumbstick Replacement, Disconnect the thumbstick interconnect cable: step 9, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the thumbstick interconnect cable: step 9, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the thumbstick interconnect cable: step 9, image 3 of 3
      Buy
      • The left thumbstick will be on your right-hand side since your device is laying upside down.
      • Use a spudger or a clean fingernail to lift the locking flap on the thumbstick interconnect cable ZIF connector, located on the left thumbstick board.
      • Use tweezers to grip the cable's blue pull tab and pull the connector straight out of its socket.
      Ask FixBot
    2. Asus ROG Ally Left Thumbstick Replacement, Disconnect the left thumbstick ring: step 10, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the left thumbstick ring: step 10, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the left thumbstick ring: step 10, image 3 of 3
      • Use the point of a spudger to lift the locking flap on the left thumbstick ring ZIF connector.
      • The black line on the ZIF connector cables mark the connection area. During reassembly, insert the cables into their sockets up to this line.
      Ask FixBot
    3. Asus ROG Ally Left Thumbstick Replacement, Peel up the main board interconnect cable tape: step 11, image 1 of 2 Asus ROG Ally Left Thumbstick Replacement, Peel up the main board interconnect cable tape: step 11, image 2 of 2
      • Use tweezers to peel up the tape covering the main board interconnect cable ZIF connector.
      Ask FixBot
    4. Asus ROG Ally Left Thumbstick Replacement, Disconnect the main board interconnect cable: step 12, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the main board interconnect cable: step 12, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Disconnect the main board interconnect cable: step 12, image 3 of 3
      • Use the flat end of a spudger or clean fingernail to lift the locking flap on the main board interconnect cable ZIF connector.
      Ask FixBot
    5. Asus ROG Ally Left Thumbstick Replacement, Unfasten the left thumbstick assembly: step 13, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Unfasten the left thumbstick assembly: step 13, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Unfasten the left thumbstick assembly: step 13, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 3.4 mm‑long screws securing the left thumbstick assembly.
      • During reassembly, keep the right edge of your device lifted while you tighten the screws so the thumbstick doesn't press against your work surface and pop out of place.
      Ask FixBot
    6. Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick assembly: step 14, image 1 of 3 Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick assembly: step 14, image 2 of 3 Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick assembly: step 14, image 3 of 3
      • Insert the flat end of a spudger between the bottom right edge of the thumbstick assembly and the chassis.
      • Pry up the thumbstick assembly and remove it.
      • During reassembly:
      • Orient the board over your device thumbstick side down.
      • Thread the thumbstick ring cable through its cutout on the board.
      • Lift the right edge of your device and push the thumbstick assembly firmly into place so the small circular cutouts on the right edge go over their alignment posts. The board should stay firmly in place.
      Ask FixBot
    7. Asus ROG Ally Left Thumbstick Replacement, Reposition the left thumbstick assembly: step 15, image 1 of 1
      • Lay the assembly on a clean cloth with the thumbstick facing up.
      Ask FixBot
    8. Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick cover: step 16, image 1 of 2 Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick cover: step 16, image 2 of 2
      • With one hand, firmly secure the thumbstick board.
      • With your free hand, pull the thumbstick cover straight up and off its module.
      • To install the thumbstick cover, rotate it on its module until it slides into place. Then firmly press down until the cover snaps into place or bottoms out.
      Ask FixBot
    9. Asus ROG Ally Left Thumbstick Replacement, Lift the left thumbstick locking flap: step 17, image 1 of 2 Asus ROG Ally Left Thumbstick Replacement, Lift the left thumbstick locking flap: step 17, image 2 of 2
      • Use the point of a spudger to lift the locking flap on the thumbstick ZIF connector.
      Ask FixBot
    10. Asus ROG Ally Left Thumbstick Replacement, Unfasten the left thumbstick: step 18, image 1 of 2 Asus ROG Ally Left Thumbstick Replacement, Unfasten the left thumbstick: step 18, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 3.4 mm‑long screws securing the thumbstick.
      Ask FixBot
    11. Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick: step 19, image 1 of 2 Asus ROG Ally Left Thumbstick Replacement, Remove the left thumbstick: step 19, image 2 of 2
      • Grab the thumbstick with your fingers and gently pull the cable out of its socket.
      • You're now left with the thumbstick and thumbstick board on their own.
      • After reassembling your device, follow this guide to calibrate your new thumbstick.
      Ask FixBot
9 other people completed this guide.
Spencer Day
197,796 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
47,937 Guides authored
2 Guide Comments
I seem to be missing a box on my new thumb stick it has a green and brown wire coming out of it
ilove TV154 - Reply Share
I'd like to know where I can purchase the left joystick thumbtack analog rod on your website?
Akash VT - Reply Share
Past 24 Hours: 21
Past 7 Days: 95
Past 30 Days: 483
All Time: 12,451
