Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓If you want faster memory (SSD) or want to increase the storage of your current Asus R558UQ-DM513D, follow this guide to replace your laptop’s current Hard Disk Drive with a new SSD/HDD.
Make sure to save your current Hard Drive data on another device before you begin.
Make sure you turn off and unplug the laptop before starting the procedure.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Using the Phillips #0 screwdriver, remove the single 5 mm screw and remove the RAM access panel.
Remove the ten 5 mm screws using the same Phillips #0 screwdriver.
