Asus R510LA-RS71 Screen Replacement
    1. Asus R510LA-RS71 Screen Replacement, Screen: step 1, image 1 of 3 Asus R510LA-RS71 Screen Replacement, Screen: step 1, image 2 of 3 Asus R510LA-RS71 Screen Replacement, Screen: step 1, image 3 of 3
      • Using a metal spudger, pick out the stoppers located on the bottom left/right corners of the screen, revealing the screws underneath them.
      • Unscrew the two 4.25mm screws with the JIS 00 screwdriver.
      Ask FixBot
    2. Asus R510LA-RS71 Screen Replacement: step 2, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 2, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 2, image 3 of 3
      • Using the metal spudger, pry off the edges of the screen's frame from the outside.
      Ask FixBot
    3. Asus R510LA-RS71 Screen Replacement: step 3, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 3, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 3, image 3 of 3
      • There should be four silver brackets holding the screen in place underneath. Unscrew the center 3.35mm screws in each bracket as shown with the JIS 00 screwdriver.
      Ask FixBot
    4. Asus R510LA-RS71 Screen Replacement: step 4, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 4, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 4, image 3 of 3
      • Slowly remove the monitor from its recess.
      Ask FixBot
    5. Asus R510LA-RS71 Screen Replacement: step 5, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 5, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 5, image 3 of 3
      • Place the monitor face down. Slowly remove the adhesive tape on the back of the monitor, and remove the connector that the tape is holding.
      Ask FixBot
3 other people completed this guide.
Deliyanis Rosa
283 Reputation
2 Guides authored
USF Tampa, Team S1-G6, Leahy Spring 2018 Member of USF Tampa, Team S1-G6, Leahy Spring 2018
USFT-LEAHY-S18S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 67
All Time: 907
