Asus R510LA-RS71 Hard Drive Replacement
    1. Asus R510LA-RS71 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Asus R510LA-RS71 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Remove the bottom left and right 12.7mm screws using a JIS 00 screwdriver.
      Ask FixBot
    2. Asus R510LA-RS71 Hard Drive Replacement: step 2, image 1 of 1
      • Slide back and remove the protective plating on the back of the laptop.
      Ask FixBot
    3. Asus R510LA-RS71 Hard Drive Replacement: step 3, image 1 of 1
      • Again with the JIS 00, unscrew the three 5.7mm screws holding the hard drive in place. These can be found on small brackets on the four corners of the drive.
      Ask FixBot
    4. Asus R510LA-RS71 Hard Drive Replacement: step 4, image 1 of 3 Asus R510LA-RS71 Hard Drive Replacement: step 4, image 2 of 3 Asus R510LA-RS71 Hard Drive Replacement: step 4, image 3 of 3
      • Slide the hard drive to the left, then remove it by lifting it from the compartment it is resting in.
      Ask FixBot
Spencer Whitworth
186 Reputation
1 Guide authored
USF Tampa, Team S1-G6, Leahy Spring 2018 Member of USF Tampa, Team S1-G6, Leahy Spring 2018
USFT-LEAHY-S18S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 772
