Asus R510CA-OB01 Keyboard and Mousepad Replacement
    1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: step 1, image 1 of 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: step 1, image 2 of 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: step 1, image 3 of 3
      • Locate the two switches that lock the battery.
      • Then, push the right switch outward to unlock it.
      Ask FixBot
    2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 2, image 1 of 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 2, image 2 of 2
      • Push the left switch outward and push the battery upward at the same time.
      Ask FixBot
    3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 3, image 1 of 1
      • Use a Li-ion battery as a replacement for your battery.
      Ask FixBot
    1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Keyboard and Mousepad: step 4, image 1 of 1
      • Shut down the computer and disconnect all external devices connected to it.
      • Turn the computers that it is upside down. Position the computer with the front towards you.
      Ask FixBot
    2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 5, image 1 of 1
      • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
      Ask FixBot
    3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 6, image 1 of 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 6, image 2 of 2
      • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
      Ask FixBot
    4. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 7, image 1 of 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 7, image 2 of 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 7, image 3 of 3
      • Use the grips to slide the panel off.
      • Remove the panel by lifting it off the device.
      Ask FixBot
    5. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 8, image 1 of 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 8, image 2 of 2
      • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
      Ask FixBot
    6. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 9, image 1 of 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 9, image 2 of 2
      • Turn the laptop the right way up and face it towards you.
      • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
      • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
      Ask FixBot
    7. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 10, image 1 of 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 10, image 2 of 2
      • Make sure that the entire cover has been released front the plastic pins.
      • Slowly lift the cover open from the front of the laptop but do not completely remove.
      • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
      Ask FixBot
    8. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 11, image 1 of 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 11, image 2 of 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 11, image 3 of 3
      • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
      • The cable will slide out of its place.
      Ask FixBot
    9. Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 12, image 1 of 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: step 12, image 2 of 2
      • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
      Ask FixBot
Blanche Pinto
461 Reputation
4 Guides authored
USF Tampa, Team S3-G4, Nance Fall 2017 Member of USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,132
