Asus R510CA-OB01 Fan Replacement
    1. Asus R510CA-OB01 Fan  Replacement, Battery: step 1, image 1 of 3 Asus R510CA-OB01 Fan  Replacement, Battery: step 1, image 2 of 3 Asus R510CA-OB01 Fan  Replacement, Battery: step 1, image 3 of 3
      • Locate the two switches that lock the battery.
      • Then, push the right switch outward to unlock it.
      Ask FixBot
    2. Asus R510CA-OB01 Fan  Replacement: step 2, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 2, image 2 of 2
      • Push the left switch outward and push the battery upward at the same time.
      Ask FixBot
    3. Asus R510CA-OB01 Fan  Replacement: step 3, image 1 of 1
      • Use a Li-ion battery as a replacement for your battery.
      Ask FixBot
    1. Asus R510CA-OB01 Fan  Replacement, Keyboard and Mousepad: step 4, image 1 of 1
      • Shut down the computer and disconnect all external devices connected to it.
      • Turn the computers that it is upside down. Position the computer with the front towards you.
      Ask FixBot
    2. Asus R510CA-OB01 Fan  Replacement: step 5, image 1 of 1
      • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
      Ask FixBot
    3. Asus R510CA-OB01 Fan  Replacement: step 6, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 6, image 2 of 2
      • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
      Ask FixBot
    4. Asus R510CA-OB01 Fan  Replacement: step 7, image 1 of 3 Asus R510CA-OB01 Fan  Replacement: step 7, image 2 of 3 Asus R510CA-OB01 Fan  Replacement: step 7, image 3 of 3
      • Use the grips to slide the panel off.
      • Remove the panel by lifting it off the device.
      Ask FixBot
    5. Asus R510CA-OB01 Fan  Replacement: step 8, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 8, image 2 of 2
      • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
      Ask FixBot
    6. Asus R510CA-OB01 Fan  Replacement: step 9, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 9, image 2 of 2
      • Turn the laptop the right way up and face it towards you.
      • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
      • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
      Ask FixBot
    7. Asus R510CA-OB01 Fan  Replacement: step 10, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 10, image 2 of 2
      • Make sure that the entire cover has been released front the plastic pins.
      • Slowly lift the cover open from the front of the laptop but do not completely remove.
      • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
      Ask FixBot
    8. Asus R510CA-OB01 Fan  Replacement: step 11, image 1 of 3 Asus R510CA-OB01 Fan  Replacement: step 11, image 2 of 3 Asus R510CA-OB01 Fan  Replacement: step 11, image 3 of 3
      • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
      • The cable will slide out of its place.
      Ask FixBot
    9. Asus R510CA-OB01 Fan  Replacement: step 12, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 12, image 2 of 2
      • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
      Ask FixBot
    1. Asus R510CA-OB01 Fan  Replacement, Optical Drive: step 13, image 1 of 2 Asus R510CA-OB01 Fan  Replacement, Optical Drive: step 13, image 2 of 2
      • Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
      • Remove the three 2mm silver screws using a Phillips #000 bit.
      • Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
      • With your hands, gently slide the optical drive out of the laptop.
      Ask FixBot
    1. Asus R510CA-OB01 Fan  Replacement, Motherboard: step 14, image 1 of 1
      • Remove the nine 5mm screws that are holding both the fan, the disk drive and motherboard in place using a Phillips #1 bit.
      Ask FixBot
    2. Asus R510CA-OB01 Fan  Replacement: step 15, image 1 of 3 Asus R510CA-OB01 Fan  Replacement: step 15, image 2 of 3 Asus R510CA-OB01 Fan  Replacement: step 15, image 3 of 3
      • Disconnect the cables from the motherboard by sliding the cable out of place.
      • Disconnect the cables connecting the fan to the motherboard and laptop by pulling the cable out of place.
      Ask FixBot
    3. Asus R510CA-OB01 Fan  Replacement: step 16, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 16, image 2 of 2
      • Lift the motherboard on the right side so that it is lifted slightly above the hard drive.
      • Slide the motherboard and fan to the right. Both components should be free from the device.
      • Once the fan and motherboard are free from the device, flip them over and remove the cable connecting both components.
      Ask FixBot
    4. Asus R510CA-OB01 Fan  Replacement: step 17, image 1 of 2 Asus R510CA-OB01 Fan  Replacement: step 17, image 2 of 2
      • Remove the four 5mm screws connecting the fan and motherboard using a Phillips #1 bit.
      • Once the screws have been removed, the fan and motherboard should come apart.
      Ask FixBot
    5. Asus R510CA-OB01 Fan  Replacement: step 18, image 1 of 1
      • The motherboard should now be free from the device .
      Ask FixBot
    1. Asus R510CA-OB01 Fan  Replacement, Fan: step 19, image 1 of 1
      • The fan should be free from the device and can now be replaced.
      Ask FixBot
Presley England
43 Reputation
1 Guide authored
IUPUI, Team S1-G2, Henning Spring 2019 Member of IUPUI, Team S1-G2, Henning Spring 2019
IUPUI-HENNING-S19S1G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 69
All Time: 850
