Asus R510CA-OB01 Display Replacement
    1. Asus R510CA-OB01 Display Replacement, Display: step 1, image 1 of 3 Asus R510CA-OB01 Display Replacement, Display: step 1, image 2 of 3 Asus R510CA-OB01 Display Replacement, Display: step 1, image 3 of 3
      • Open the device.
      • Remove the black plastic squares on each side with a spudger.
      Ask FixBot
    2. Asus R510CA-OB01 Display Replacement: step 2, image 1 of 2 Asus R510CA-OB01 Display Replacement: step 2, image 2 of 2
      • Remove the two 5mm screws at each bottom corner of the display using a Phillips #0 screwdriver.
      Ask FixBot
    3. Asus R510CA-OB01 Display Replacement: step 3, image 1 of 3 Asus R510CA-OB01 Display Replacement: step 3, image 2 of 3 Asus R510CA-OB01 Display Replacement: step 3, image 3 of 3
      • After the two screws are removed, use a plastic opening tool to remove the black cover around the screen.
      Ask FixBot
    4. Asus R510CA-OB01 Display Replacement: step 4, image 1 of 3 Asus R510CA-OB01 Display Replacement: step 4, image 2 of 3 Asus R510CA-OB01 Display Replacement: step 4, image 3 of 3
      • Remove the four 5mm screws that attach the screen with a Philips #0 screwdriver.
      Ask FixBot
    5. Asus R510CA-OB01 Display Replacement: step 5, image 1 of 2 Asus R510CA-OB01 Display Replacement: step 5, image 2 of 2
      • Lift up the screen from the back of the laptop and then you will see a cable connected to the screen.
      • You can simply disconnect the cable and insert a new screen.
      Ask FixBot
Blanche Pinto
461 Reputation
4 Guides authored
USF Tampa, Team S3-G4, Nance Fall 2017 Member of USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 115
All Time: 958
