Asus R510CA-OB01 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
94
All Time:
732
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to remove the battery in the Asus R510CA-OB01. In the event that your laptop doesn't charge, or doesn't work in general, you can use this guide to replace the battery in your device.
    1. Asus R510CA-OB01 Battery Replacement, Battery: step 1, image 1 of 3 Asus R510CA-OB01 Battery Replacement, Battery: step 1, image 2 of 3 Asus R510CA-OB01 Battery Replacement, Battery: step 1, image 3 of 3
      • Locate the two switches that lock the battery.
      • Then, push the right switch outward to unlock it.
      Ask FixBot
    2. Asus R510CA-OB01 Battery Replacement: step 2, image 1 of 2 Asus R510CA-OB01 Battery Replacement: step 2, image 2 of 2
      • Push the left switch outward and push the battery upward at the same time.
      Ask FixBot
    3. Asus R510CA-OB01 Battery Replacement: step 3, image 1 of 1
      • Use a Li-ion battery as a replacement for your battery.
      Ask FixBot
Blanche Pinto
461 Reputation
4 Guides authored
USF Tampa, Team S3-G4, Nance Fall 2017 Member of USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 94
All Time: 732
