Asus Q552UB-BHI7T12 RAM Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
91
All Time:
1,565
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
RAM (Random Access Memory) is also known as system memory. Generally, 12 GB (8 GB and 4 GB) RAM is given by default with the Asus Q552UB-BHI7T12 Laptop. But users can upgrade up to 16 GB using two 8 GB RAMs. Normally the user needs to change the RAM when its performance degrades therefore the system becomes slower. But before changing the RAM, an Asus Q552UB-BHI7T12 user needs to confirm here that it’s actually the RAM which is causing the problem, not the CPU or Graphics Card.
Use this simple guide to replace your Asus Q552UB-BHI7T12 RAM. Follow these three simple steps which will take no longer than 10 minutes.
    1. Asus Q552UB-BHI7T12 RAM Replacement, RAM: step 1, image 1 of 2 Asus Q552UB-BHI7T12 RAM Replacement, RAM: step 1, image 2 of 2
      • On the bottom of the laptop, gently pull the wire connecting the battery to the motherboard
      Ask FixBot
    2. Asus Q552UB-BHI7T12 RAM Replacement: step 2, image 1 of 1
      • Gently lever the two arms securing the RAM toward either side of the laptop, while holding the RAM in place with your thumbs.
      Ask FixBot
    3. Asus Q552UB-BHI7T12 RAM Replacement: step 3, image 1 of 1
      • Carefully slide the ram with your index fingers from in between the white tabs.
      Ask FixBot
To reassemble device, follow the instructions in reverse order.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 91
All Time: 1,565
