Up to 20% off select tools
Asus Q551L Screen Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
69
All Time:
3,878
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is intended to show how to remove a damaged screen from the laptop. Reversing the steps will describe the steps needed to replace the laptop with a new screen.
    1. Asus Q551L Screen Replacement, Back Panel: step 1, image 1 of 2 Asus Q551L Screen Replacement, Back Panel: step 1, image 2 of 2
      • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
      Ask FixBot
    2. Asus Q551L Screen Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to pry the back panel off the base of the laptop.
      Ask FixBot
    1. Asus Q551L Screen Replacement, Battery: step 3, image 1 of 2 Asus Q551L Screen Replacement, Battery: step 3, image 2 of 2
      • Unscrew the four screws to remove the battery.
      Ask FixBot
    2. Asus Q551L Screen Replacement: step 4, image 1 of 2 Asus Q551L Screen Replacement: step 4, image 2 of 2
      • Un-clip both wire clips on the upper and right side of the battery.
      • Lift the battery out of the device.
      Ask FixBot
    1. Asus Q551L Screen Replacement, Screen: step 5, image 1 of 2 Asus Q551L Screen Replacement, Screen: step 5, image 2 of 2
      • Use the metal spudger to gently lift the two plastic squares off the screen.
      Ask FixBot
    2. Asus Q551L Screen Replacement: step 6, image 1 of 2 Asus Q551L Screen Replacement: step 6, image 2 of 2
      • Unscrew the two PH0 screws and set them aside.
      Ask FixBot
    3. Asus Q551L Screen Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to pry the front edges of the screen off of the back.
      Ask FixBot
    4. Asus Q551L Screen Replacement: step 8, image 1 of 1
      • Take off the tapes.
      • Gently pry the LCD from the front frame.
      Ask FixBot
4 other people completed this guide.
Author
with
Colleen Ford
327 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 69
All Time: 3,878
