Asus Q551L Repair Optical Drive Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
67
All Time:
1,111
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will describe how to remove and replace the optical drive on the Asus Q551L. It is a simple procedure that involves unscrewing a few screws and sliding the optical drive out. The optical drive may need to be replaced if disks are not being read in the device, or if disks are continually getting stuck or jammed in the optical drive. The optical drive is the component of the device where disks are inserted.
Tools
    1. Asus Q551L Repair Optical Drive Replacement, Back Panel: step 1, image 1 of 2 Asus Q551L Repair Optical Drive Replacement, Back Panel: step 1, image 2 of 2
      • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
      Ask FixBot
    2. Asus Q551L Repair Optical Drive Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to pry the back panel off the base of the laptop.
      Ask FixBot
    1. Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): step 3, image 1 of 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): step 3, image 2 of 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): step 3, image 3 of 3
      • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
      • Watch out for the wires around the optical drive.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 67
All Time: 1,111
