Asus Q551L Repair Motherboard Replacement
    1. Asus Q551L Repair Motherboard Replacement, Back Panel: step 1, image 1 of 2 Asus Q551L Repair Motherboard Replacement, Back Panel: step 1, image 2 of 2
      • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
      Ask FixBot
    2. Asus Q551L Repair Motherboard Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to pry the back panel off the base of the laptop.
      Ask FixBot
    1. Asus Q551L Repair Motherboard Replacement, Battery: step 3, image 1 of 2 Asus Q551L Repair Motherboard Replacement, Battery: step 3, image 2 of 2
      • Unscrew the four screws to remove the battery.
      Ask FixBot
    2. Asus Q551L Repair Motherboard Replacement: step 4, image 1 of 2 Asus Q551L Repair Motherboard Replacement: step 4, image 2 of 2
      • Un-clip both wire clips on the upper and right side of the battery.
      • Lift the battery out of the device.
      Ask FixBot
    1. Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): step 5, image 1 of 3 Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): step 5, image 2 of 3 Asus Q551L Repair Motherboard Replacement, Optical Drive (PN UJ8E2): step 5, image 3 of 3
      • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
      • Watch out for the wires around the optical drive.
      Ask FixBot
    1. Asus Q551L Repair Motherboard Replacement, Motherboard: step 6, image 1 of 3 Asus Q551L Repair Motherboard Replacement, Motherboard: step 6, image 2 of 3 Asus Q551L Repair Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Remove the fan by unscrewing the nine screws shown in the images.
      • The four colored wire and the black cable need to be pulled out gently.
      • There will be wires around the fan. Make sure they are not stuck to it.
      • You want to keep the fan if it still in good conditions.
      Ask FixBot
    2. Asus Q551L Repair Motherboard Replacement: step 7, image 1 of 2 Asus Q551L Repair Motherboard Replacement: step 7, image 2 of 2
      • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
      Ask FixBot
    3. Asus Q551L Repair Motherboard Replacement: step 8, image 1 of 3 Asus Q551L Repair Motherboard Replacement: step 8, image 2 of 3 Asus Q551L Repair Motherboard Replacement: step 8, image 3 of 3
      • Disconnect any cables that hold the motherboard.
      • Open up the white adjustable latch first to pull out the tapes.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 39
All Time: 2,907
