Asus Q550LF-BBI7T07 RAM Replacement
    1. Asus Q550LF-BBI7T07 RAM Replacement, Battery: step 1, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement, Battery: step 1, image 2 of 2
      • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
      Ask FixBot
    2. Asus Q550LF-BBI7T07 RAM Replacement: step 2, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 2, image 2 of 2
      • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
      Ask FixBot
    3. Asus Q550LF-BBI7T07 RAM Replacement: step 3, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
      Ask FixBot
    4. Asus Q550LF-BBI7T07 RAM Replacement: step 4, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 4, image 2 of 2
      • Once the screws have been removed, gently lift the battery out.
      Ask FixBot
    1. Asus Q550LF-BBI7T07 RAM Replacement, RAM: step 5, image 1 of 3 Asus Q550LF-BBI7T07 RAM Replacement, RAM: step 5, image 2 of 3 Asus Q550LF-BBI7T07 RAM Replacement, RAM: step 5, image 3 of 3
      • Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
      Ask FixBot
    2. Asus Q550LF-BBI7T07 RAM Replacement: step 6, image 1 of 1
      • Pull out first RAM chip.
      Ask FixBot
    3. Asus Q550LF-BBI7T07 RAM Replacement: step 7, image 1 of 1
      • Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
      Ask FixBot
    4. Asus Q550LF-BBI7T07 RAM Replacement: step 8, image 1 of 2 Asus Q550LF-BBI7T07 RAM Replacement: step 8, image 2 of 2
      • Pull out second RAM chip.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 71
All Time: 1,141
