Asus Q550LF-BBI7T07 Disc Drive Replacement
    1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: step 1, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: step 1, image 2 of 2
      • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
      Ask FixBot
    2. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 2, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 2, image 2 of 2
      • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
      Ask FixBot
    3. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 3, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
      Ask FixBot
    4. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 4, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 4, image 2 of 2
      • Once the screws have been removed, gently lift the battery out.
      Ask FixBot
    1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: step 5, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: step 5, image 2 of 2
      • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
      Ask FixBot
    2. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 6, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 6, image 2 of 2
      • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
      Ask FixBot
    1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: step 7, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: step 7, image 2 of 2
      • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
      Ask FixBot
    2. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 8, image 1 of 1
      • Lift the metal disc drive holder off of the disc drive to remove it.
      Ask FixBot
    3. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 9, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 9, image 2 of 2
      • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
      Ask FixBot
    4. Asus Q550LF-BBI7T07 Disc Drive Replacement: step 10, image 1 of 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: step 10, image 2 of 2
      • Slowly slide out the disc drive, keeping it level, to remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 32
All Time: 723
