Asus Q534U Wi-fi card Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
109
All Time:
3,811
Comments: 6
6 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Asus laptop (Q534U) is having problems connecting to WiFi, then the solution may be as simple as switching out a faulty WiFi card. First, be sure to eliminate all the possible errors with the laptop. Once the problem has been narrowed down to the WiFi card, use this guide to walk you through the steps of changing the WiFi card. This fix should not take more than 20 minutes, and only requires removal of parts.
It does require removing the battery, so use caution as a punctured battery can cause a dangerous fire.
Tools
    1. Asus Q534U Wi-fi card Replacement, Back Case Removal: step 1, image 1 of 1
      • Make sure the device is turned off and unplugged from the charger.
      • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
      • Pull off the back cover of the laptop.
      • A pry tool may be needed to pull off the back cover.
      Ask FixBot
    2. Asus Q534U Wi-fi card Replacement: step 2, image 1 of 2 Asus Q534U Wi-fi card Replacement: step 2, image 2 of 2
      • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
      Ask FixBot
    3. Asus Q534U Wi-fi card Replacement: step 3, image 1 of 2 Asus Q534U Wi-fi card Replacement: step 3, image 2 of 2
      • Lift up the black tab next to the silver ribbon cable.
      • Pull lightly on the blue tabs until the silver cable is free.
      Ask FixBot
    4. Asus Q534U Wi-fi card Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 5 marked screws.
      • Gently remove the battery.
      • Do not bend or puncture the laptop's lithium-polymer pattery.
      Ask FixBot
    1. Asus Q534U Wi-fi card Replacement, Wi-Fi card: step 5, image 1 of 1
      • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
      • Needle nose pliers can be used as a detaching tool.
      Ask FixBot
    2. Asus Q534U Wi-fi card Replacement: step 6, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
      • Pull the WiFi card out of the socket toward the fan housing.
      Ask FixBot
Eric Okoko
327 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 109
All Time: 3,811
