Up to 20% off select tools
Asus Q534U RAM Replacement
Views: 8.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
92
All Time:
8,657
Comments: 18
14 comments on steps, 4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the RAM in your Asus Q534U laptop. Perhaps your laptop is experiencing slow-downs with multiple programs open, signaling that you may need to upgrade to a larger amount of RAM. Or maybe your laptop won’t boot, indicating that your current RAM may be faulty. If you need to upgrade to a larger capacity RAM stick, or if your current RAM is faulty and in need of replacement, this guide will help you through the process.
The RAM is located underneath a metal cover on the motherboard so it will not be immediately visible upon opening the case. However, the metal cover can be easily pried from the motherboard, for it is affixed by a clip mechanism rather than screws or glue. To replace the metal cover, be sure to align all four sides of the cover with each of the clips and simply press it into place.
    1. Asus Q534U RAM Replacement, Back Case Removal: step 1, image 1 of 1
      • Make sure the device is turned off and unplugged from the charger.
      • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
      • Pull off the back cover of the laptop.
      • A pry tool may be needed to pull off the back cover.
      Ask FixBot
    2. Asus Q534U RAM Replacement: step 2, image 1 of 2 Asus Q534U RAM Replacement: step 2, image 2 of 2
      • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
      Ask FixBot
    3. Asus Q534U RAM Replacement: step 3, image 1 of 2 Asus Q534U RAM Replacement: step 3, image 2 of 2
      • Lift up the black tab next to the silver ribbon cable.
      • Pull lightly on the blue tabs until the silver cable is free.
      Ask FixBot
    4. Asus Q534U RAM Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 5 marked screws.
      • Gently remove the battery.
      • Do not bend or puncture the laptop's lithium-polymer pattery.
      Ask FixBot
    1. Asus Q534U RAM Replacement, RAM: step 5, image 1 of 3 Asus Q534U RAM Replacement, RAM: step 5, image 2 of 3 Asus Q534U RAM Replacement, RAM: step 5, image 3 of 3
      • Locate the metal RAM cover
      • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
      • A pry tool may provide a better grip on small tab.
      Ask FixBot
    2. Asus Q534U RAM Replacement: step 6, image 1 of 3 Asus Q534U RAM Replacement: step 6, image 2 of 3 Asus Q534U RAM Replacement: step 6, image 3 of 3
      • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
      • Pull the RAM out gently and bring it up from the slot
      • Make sure to pull out first and then pull the RAM up out of place
      Ask FixBot
5 other people completed this guide.
Author
with
Kyle Whalen
181 Reputation
1 Guide authored
4 Guide Comments
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - Reply Share
saame here must be another stick somewhere
SvGGRK - Reply Share
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - Reply Share
This is too old but I hope someone can help me. I open the memory section just to clean all the dust accumulated there. After putting everything back laptop is bricked... Battery led is green. Power led is on but laptop is not booting. Any ideas?
Mario Venegas - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 92
All Time: 8,657
