Asus Q534U Motherboard Replacement
    1. Asus Q534U Motherboard Replacement, Back Case: step 1, image 1 of 3 Asus Q534U Motherboard Replacement, Back Case: step 1, image 2 of 3 Asus Q534U Motherboard Replacement, Back Case: step 1, image 3 of 3
      • Remove ten screws with the T5 driver.
      • Use the opening tool to carefully pry off the back case.
      Ask FixBot
    1. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: step 2, image 1 of 2 Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: step 2, image 2 of 2
      • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
      Ask FixBot
    2. Asus Q534U Motherboard Replacement: step 3, image 1 of 2 Asus Q534U Motherboard Replacement: step 3, image 2 of 2
      • Move the black cable located around the CPU fan out of the holder.
      • Remove the following 9 screws:
      • Three Phillips screws
      • Six Phillips screws
      • Make sure not to mix up both types of screws.
      • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
      • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
      Ask FixBot
    1. Asus Q534U Motherboard Replacement, Hard Drive: step 4, image 1 of 2 Asus Q534U Motherboard Replacement, Hard Drive: step 4, image 2 of 2
      • Remove four screws with the Phillips #00 screwdriver.
      Ask FixBot
    2. Asus Q534U Motherboard Replacement: step 5, image 1 of 2 Asus Q534U Motherboard Replacement: step 5, image 2 of 2
      • Gently lift the hard disk out using the black tab.
      Ask FixBot
    3. Asus Q534U Motherboard Replacement: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver remove the four screws of the metal casing
      • Remove the hard disk from the metal casing
      Ask FixBot
    1. Asus Q534U Motherboard Replacement, Motherboard: step 7, image 1 of 3 Asus Q534U Motherboard Replacement, Motherboard: step 7, image 2 of 3 Asus Q534U Motherboard Replacement, Motherboard: step 7, image 3 of 3
      • Disconnect the four marked cables connectors at the sockets.
      Ask FixBot
    2. Asus Q534U Motherboard Replacement: step 8, image 1 of 3 Asus Q534U Motherboard Replacement: step 8, image 2 of 3 Asus Q534U Motherboard Replacement: step 8, image 3 of 3
      • Lift the connecting ports up prior to removing the connectors.
      Ask FixBot
    3. Asus Q534U Motherboard Replacement: step 9, image 1 of 3 Asus Q534U Motherboard Replacement: step 9, image 2 of 3 Asus Q534U Motherboard Replacement: step 9, image 3 of 3
      • Remove the screws holding the hinges down on both sides of the device.
      • A pry tool might be needed to lift the hinge.
      Ask FixBot
    4. Asus Q534U Motherboard Replacement: step 10, image 1 of 1
      • Remove nine, 3.2 mm screws to fully release motherboard.
      Ask FixBot
2 other people completed this guide.
Jacob Pauker
238 Reputation
2 Guides authored
IUPUI, Team S1-G9, Hovde Fall 2019 Member of IUPUI, Team S1-G9, Hovde Fall 2019
IUPUI-HOVDE-F19S1G9
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 67
All Time: 2,831
