Asus Q534U Battery Replacement
    1. Asus Q534U Battery Replacement, Back Case Removal: step 1, image 1 of 1
      • Make sure the device is turned off and unplugged from the charger.
      • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
      • Pull off the back cover of the laptop.
      • A pry tool may be needed to pull off the back cover.
      Ask FixBot
    2. Asus Q534U Battery Replacement: step 2, image 1 of 2 Asus Q534U Battery Replacement: step 2, image 2 of 2
      • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
      Ask FixBot
    3. Asus Q534U Battery Replacement: step 3, image 1 of 2 Asus Q534U Battery Replacement: step 3, image 2 of 2
      • Lift up the black tab next to the silver ribbon cable.
      • Pull lightly on the blue tabs until the silver cable is free.
      Ask FixBot
    4. Asus Q534U Battery Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 5 marked screws.
      • Gently remove the battery.
      • Do not bend or puncture the laptop's lithium-polymer pattery.
      Ask FixBot
18 other people completed this guide.
mmedina
827 Reputation
2 Guides authored
7 Guide Comments
Is there a website link where I can get a replacement battery for ASUS Q534 UXK ? Model year 2016.
Lalith Sharavan - Reply Share
Can this laptop be used without a battery?
Thomas Zakrzewski - Reply Share
Thomas, yes. I found that out by mistake when I didn’t fully connect/lock the new cable and had to go back in and reconnect it. Worked as usual on AC power.
mmedina - thanks for the step by step. Worked like a champ for me.
Jeff Nurkiewicz - Reply Share
Dear IFixIt,
Thank you for this straightforward approach to changing the battery on my ASUS Laptop Model Q534UX BHI7T19. The first attempt was 100% successful!! I can say that opening the laptop base was a little scary, but your step-by-step details removed enough fear of me screwing something up that I went for it!! Having the right tools on hand went a long way to getting fast results and great outcome. I highly advise viewers to purchase a tool set to remove the tiny screws and a plastic pry tool set (the one I purchased from Amazon was only $18 and included both) to make this task almost effortless. Without your guidance, I never would have attempted this project. Thanks again!!
Do you have similar guidance for changing out the hard drives on the above ASUS??
sheri scott - Reply Share
Hi Sheri, thanks for your message! We’re so happy this guide was helpful. We have a hard drive guide as well. Check out the Asus Q534U device page, there are several other guides in addition to the battery guide. Thanks again!
Sarah Westberg - Reply Share
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 165
All Time: 14,448
