Asus Q525U CPU Fan Replacement
    1. Asus Q525U CPU Fan Replacement, Back Cover: step 1, image 1 of 3 Asus Q525U CPU Fan Replacement, Back Cover: step 1, image 2 of 3 Asus Q525U CPU Fan Replacement, Back Cover: step 1, image 3 of 3
      • Begin by powering off the device and flipping the device over.
      • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
      • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
      Ask FixBot
    2. Asus Q525U CPU Fan Replacement: step 2, image 1 of 3 Asus Q525U CPU Fan Replacement: step 2, image 2 of 3 Asus Q525U CPU Fan Replacement: step 2, image 3 of 3
      • Use an opening pick to separate the back cover from the device.
      • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
      Ask FixBot
    3. Asus Q525U CPU Fan Replacement: step 3, image 1 of 3 Asus Q525U CPU Fan Replacement: step 3, image 2 of 3 Asus Q525U CPU Fan Replacement: step 3, image 3 of 3
      • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
      • The back cover should be easily removable, allowing full access to all of the internal components.
      Ask FixBot
    1. Asus Q525U CPU Fan Replacement, Battery: step 4, image 1 of 3 Asus Q525U CPU Fan Replacement, Battery: step 4, image 2 of 3 Asus Q525U CPU Fan Replacement, Battery: step 4, image 3 of 3
      • The battery of the device is outlined in red.
      • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
      Ask FixBot
    2. Asus Q525U CPU Fan Replacement: step 5, image 1 of 2 Asus Q525U CPU Fan Replacement: step 5, image 2 of 2
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
      Ask FixBot
    3. Asus Q525U CPU Fan Replacement: step 6, image 1 of 1
      • Lift the battery out of the frame to remove.
      Ask FixBot
    1. Asus Q525U CPU Fan Replacement, CPU Fan: step 7, image 1 of 1
      • The CPU fan of this device is outlined in purple.
      Ask FixBot
    2. Asus Q525U CPU Fan Replacement: step 8, image 1 of 3 Asus Q525U CPU Fan Replacement: step 8, image 2 of 3 Asus Q525U CPU Fan Replacement: step 8, image 3 of 3
      • Using a Phillips #1 screwdriver, remove five screws from the fan and heatsink.
      • Remove one 3 mm Phillips #1 screw on the side of the CPU fan.
      • Remove four 2 mm Phillips #1 screws from the heatsink.
      Ask FixBot
    3. Asus Q525U CPU Fan Replacement: step 9, image 1 of 2 Asus Q525U CPU Fan Replacement: step 9, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Use the Halberd spudger to carefully disconnect the bundled slide connector that connects the CPU fan to the motherboard.
      • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
      Ask FixBot
    4. Asus Q525U CPU Fan Replacement: step 10, image 1 of 3 Asus Q525U CPU Fan Replacement: step 10, image 2 of 3 Asus Q525U CPU Fan Replacement: step 10, image 3 of 3
      • Carefully remove the thicker black cord from the cord clips surrounding the fan.
      • Remove the fan from the device.
      Ask FixBot
Stewart Crandall
634 Reputation
5 Guides authored
Clemson, Team 2-5, Hunter Spring 2022 Member of Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 62
All Time: 937
