Up to 20% off select tools
Asus Q524U RAM Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
70
All Time:
1,913
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove and replace the RAM card of the ASUS Q524U (Asus Q524UQ). The RAM is also known as the random access memory. All computers use RAM to run all programs and applications. Upgrading your RAM will allow you to run larger programs like video games.
    1. Asus Q524U RAM Replacement, Back Panel: step 1, image 1 of 2 Asus Q524U RAM Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 3 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Asus Q524U RAM Replacement: step 2, image 1 of 1
      • Lift up the back panel and set it to the side.
      Ask FixBot
    1. Asus Q524U RAM Replacement, RAM: step 3, image 1 of 2 Asus Q524U RAM Replacement, RAM: step 3, image 2 of 2
      • With your finger, lift the RAM cover by pushing on the small tab in one of the corners.
      Ask FixBot
    2. Asus Q524U RAM Replacement: step 4, image 1 of 1
      • Lift the RAM cover up and put it aside.
      Ask FixBot
    3. Asus Q524U RAM Replacement: step 5, image 1 of 3 Asus Q524U RAM Replacement: step 5, image 2 of 3 Asus Q524U RAM Replacement: step 5, image 3 of 3
      • Push these two tabs outwards with your fingers.
      • This will release the RAM.
      Ask FixBot
    4. Asus Q524U RAM Replacement: step 6, image 1 of 1
      • Grab the RAM card out of its slot.
      Ask FixBot
3 other people completed this guide.
Author
with
Leonardo Pena
505 Reputation
4 Guides authored
1 Guide Comment
Excellent! Short and to the point. Pictures are worth a thousand words.
Eric - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 70
All Time: 1,913
