Asus Q524U Battery Replacement
    1. Asus Q524U Battery Replacement, Back Panel: step 1, image 1 of 2 Asus Q524U Battery Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 3 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Asus Q524U Battery Replacement: step 2, image 1 of 1
      • Lift up the back panel and set it to the side.
      Ask FixBot
    1. Asus Q524U Battery Replacement, Battery: step 3, image 1 of 2 Asus Q524U Battery Replacement, Battery: step 3, image 2 of 2
      • Using your fingers, grip onto both sides of the wire harness and push it upwards.
      Ask FixBot
    2. Asus Q524U Battery Replacement: step 4, image 1 of 2 Asus Q524U Battery Replacement: step 4, image 2 of 2
      • Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
      Ask FixBot
    3. Asus Q524U Battery Replacement: step 5, image 1 of 3 Asus Q524U Battery Replacement: step 5, image 2 of 3 Asus Q524U Battery Replacement: step 5, image 3 of 3
      • Tilt the small black tab up which will allow the blue tape to be slid out.
      Ask FixBot
    4. Asus Q524U Battery Replacement: step 6, image 1 of 1
      • Simply lift the battery up and out of its holding area.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 80
All Time: 915
