Asus Q501LA-BBI6T03 Wireless Card Replacement
    1. Asus Q501LA-BBI6T03 Wireless Card Replacement, Back Panel: step 1, image 1 of 1
      • Ensure the laptop is powered down before continuing.
      • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
      Ask FixBot
    2. Asus Q501LA-BBI6T03 Wireless Card Replacement: step 2, image 1 of 1
      • Use the spudger to pry open the rear cover at either hinge.
      Ask FixBot
    3. Asus Q501LA-BBI6T03 Wireless Card Replacement: step 3, image 1 of 2 Asus Q501LA-BBI6T03 Wireless Card Replacement: step 3, image 2 of 2
      • Grab the cover with your fingers and gently lift it away from the board.
      • Be careful not to break any tabs on the cover when lifting it off.
      Ask FixBot
    1. Asus Q501LA-BBI6T03 Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
      • Pull up on the two metal tabs attached to the card .
      • Unscrew the single 2mm Phillips #0 screw in the top right hand corner.
      Ask FixBot
    2. Asus Q501LA-BBI6T03 Wireless Card Replacement: step 5, image 1 of 1
      • Gently slide the card out of its connection ports.
      • Make sure to pull straight out of the connection ports to avoid bending of the card or port.
      Ask FixBot
Once finished, follow prerequisite guide in reverse order to finish your repair.
3 other people completed this guide.
Aodhan Arias
288 Reputation
2 Guides authored
Cal Poly, Team 8-1, Banghart Winter 2017 Member of Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Members
72 Guides authored
2 Guide Comments
My Asus Q501L laptop cannot start the wifi card despite having updated the driver and restarting. Troubleshooting returns error Code 10. Did you experience or know how to resolve this problem?
Tony Ly - Reply Share
Hey there Tony,
I would recommend first checking the status of the hardware device first. You can view a device's status from the device's Properties in Device Manager. It is possible that the driver is corrupted even though it is “updated” fully and could be causing the issue. If so, remove and reinstall the drivers for the device. It could also be that the WiFi card has a hardware issue. There isn’t really anything I know of that you can do besides just replacing it if that’s the case. If it’s new it might be under warrantee but who knows. Unfortunately Code 10 errors are pretty vague and don’t really give a lot of information. Hope this helps.
Aodhan Arias - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,275
