Asus Q501LA-BBI6T03 RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
96
All Time:
1,048
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your RAM needs to be replaced then this guide will show you how to properly do so.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Asus Q501LA-BBI6T03 RAM Replacement, Back Panel: step 1, image 1 of 1
      • Ensure the laptop is powered down before continuing.
      • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
      Ask FixBot
    2. Asus Q501LA-BBI6T03 RAM Replacement: step 2, image 1 of 1
      • Use the spudger to pry open the rear cover at either hinge.
      Ask FixBot
    3. Asus Q501LA-BBI6T03 RAM Replacement: step 3, image 1 of 2 Asus Q501LA-BBI6T03 RAM Replacement: step 3, image 2 of 2
      • Grab the cover with your fingers and gently lift it away from the board.
      • Be careful not to break any tabs on the cover when lifting it off.
      Ask FixBot
    1. Asus Q501LA-BBI6T03 RAM Replacement, RAM: step 4, image 1 of 2 Asus Q501LA-BBI6T03 RAM Replacement, RAM: step 4, image 2 of 2
      • Press down the metal tabs on both sides of the RAM.
      • The tabs are spring loaded and the RAM will pop up immediately.
      Ask FixBot
3 other people completed this guide.
Tanner
276 Reputation
2 Guides authored
Cal Poly, Team 8-1, Banghart Winter 2017 Member of Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 96
All Time: 1,048
