Asus Q501LA-BBI6T03 Back Panel Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
99
All Time:
1,033
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk users through the disassembly of their Asus device.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Asus Q501LA-BBI6T03 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Ensure the laptop is powered down before continuing.
      • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
      Ask FixBot
    2. Asus Q501LA-BBI6T03 Back Panel Replacement: step 2, image 1 of 1
      • Use the spudger to pry open the rear cover at either hinge.
      Ask FixBot
    3. Asus Q501LA-BBI6T03 Back Panel Replacement: step 3, image 1 of 2 Asus Q501LA-BBI6T03 Back Panel Replacement: step 3, image 2 of 2
      • Grab the cover with your fingers and gently lift it away from the board.
      • Be careful not to break any tabs on the cover when lifting it off.
      Ask FixBot
2 other people completed this guide.
Tanner
276 Reputation
2 Guides authored
Cal Poly, Team 8-1, Banghart Winter 2017 Member of Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Members
72 Guides authored
1 Guide Comment
I got one of these model, how much RAM is the maximum amount supported?
Cesar Aguilar - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 99
All Time: 1,033
