Up to 20% off select tools
Asus Q500A RAM Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
110
All Time:
1,492
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If the device crashes while doing multiple tasks simultaneously, it is possibly due to insufficient amounts of ram. Replacing your ram will improve your computer's performance. This guide will properly demonstrate how to replace the RAM in the Asus Q500A laptop effectively.
    1. Asus Q500A RAM Replacement, RAM: step 1, image 1 of 2 Asus Q500A RAM Replacement, RAM: step 1, image 2 of 2
      • Flip device upside-down.
      • Remove back-plate by unscrewing the two screws on either side of the back-plate.
      • Remove the plastic cover.
      Ask FixBot
    2. Asus Q500A RAM Replacement: step 2, image 1 of 1
      • Depending on the model of the device, there will either be one or two sticks of ram.
      • There are two metal brackets holding each ram stick in.
      • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
      Ask FixBot
    3. Asus Q500A RAM Replacement: step 3, image 1 of 2 Asus Q500A RAM Replacement: step 3, image 2 of 2
      • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
      Ask FixBot
    4. Asus Q500A RAM Replacement: step 4, image 1 of 1
      • To insert the ram line up the ram stick and the slot.
      • Next you will have to push the ram down until it snaps into place.
      • Be careful not to do this too hard, as it can break the ram.
      • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
      Ask FixBot
Author
with
cameron
319 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2017 Member of USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 110
All Time: 1,492
