Asus Q500A Hard Drive Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
104
All Time:
1,386
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the hard drive on the Asus Q500A.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Asus Q500A Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Flip device onto backside
      Ask FixBot
    2. Asus Q500A Hard Drive Replacement: step 2, image 1 of 1
      • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
      • Remove back-plate.
      • Note: Use prying tool if your having issues lifting back-plate.
      Ask FixBot
    3. Asus Q500A Hard Drive Replacement: step 3, image 1 of 2 Asus Q500A Hard Drive Replacement: step 3, image 2 of 2
      • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
      • Remove the hard-drive case from the device.
      Ask FixBot
    4. Asus Q500A Hard Drive Replacement: step 4, image 1 of 1
      • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
      Ask FixBot
      • Place hard-drive into slot and connect to the integrated sata port.
      • Place hard drive case back on top of the new hard-drive.
      • Screw in the four screws on the hard-drive case.
      Ask FixBot
    5. Asus Q500A Hard Drive Replacement: step 6, image 1 of 1
      • Place back-plate back on device.
      • Screw in the 2 screws on the back of the plate.
      Ask FixBot
2 other people completed this guide.
cameron
319 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2017 Member of USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 104
All Time: 1,386
