Asus Q500A Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
100
All Time:
930
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the battery in the Asus Q500A.
    1. Asus Q500A Battery Replacement, Battery: step 1, image 1 of 1
      • Flip device onto backside.
      Ask FixBot
    2. Asus Q500A Battery Replacement: step 2, image 1 of 1
      • Locate the two sliding locks.
      • Slide the sliding lock 1 to the right to unlock it .
      • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
      Ask FixBot
    3. Asus Q500A Battery Replacement: step 3, image 1 of 1
      • Slide the sliding lock 2 to the left to unlock it.
      • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
      Ask FixBot
    4. Asus Q500A Battery Replacement: step 4, image 1 of 1
      • While the first and second lock are unlocked, slide the battery out to remove it.
      • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
      Ask FixBot
cameron
319 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2017 Member of USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 930
