Asus Q325U SSD Replacement
    1. Asus Q325U SSD Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U SSD Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U SSD Replacement, Back Panel: step 1, image 3 of 3
      • Remove the ten 5mm screws using a T5 Torx screwdriver.
      Ask FixBot
    2. Asus Q325U SSD Replacement: step 2, image 1 of 3 Asus Q325U SSD Replacement: step 2, image 2 of 3 Asus Q325U SSD Replacement: step 2, image 3 of 3
      • Lift the back panel upward using the suction tool.
      Ask FixBot
    1. Asus Q325U SSD Replacement, SSD: step 3, image 1 of 2 Asus Q325U SSD Replacement, SSD: step 3, image 2 of 2
      • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
      Ask FixBot
    2. Asus Q325U SSD Replacement: step 4, image 1 of 2 Asus Q325U SSD Replacement: step 4, image 2 of 2
      • Carefully slide and lift the SSD to remove it.
      Ask FixBot
2 other people completed this guide.
Jacob Tang
401 Reputation
3 Guides authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 59
All Time: 1,482
