Up to 20% off select tools
Asus Q325U Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
12
Past 30 Days:
55
All Time:
1,200
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to remove the keyboard in your Asus Q325U.
    1. Asus Q325U Keyboard Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U Keyboard Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U Keyboard Replacement, Back Panel: step 1, image 3 of 3
      • Remove the ten 5mm screws using a T5 Torx screwdriver.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 2, image 1 of 3 Asus Q325U Keyboard Replacement: step 2, image 2 of 3 Asus Q325U Keyboard Replacement: step 2, image 3 of 3
      • Lift the back panel upward using the suction tool.
      Ask FixBot
    1. Asus Q325U Keyboard Replacement, SSD: step 3, image 1 of 2 Asus Q325U Keyboard Replacement, SSD: step 3, image 2 of 2
      • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 4, image 1 of 2 Asus Q325U Keyboard Replacement: step 4, image 2 of 2
      • Carefully slide and lift the SSD to remove it.
      Ask FixBot
    1. Asus Q325U Keyboard Replacement, Battery: step 5, image 1 of 2 Asus Q325U Keyboard Replacement, Battery: step 5, image 2 of 2
      • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 6, image 1 of 2 Asus Q325U Keyboard Replacement: step 6, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
      Ask FixBot
    3. Asus Q325U Keyboard Replacement: step 7, image 1 of 2 Asus Q325U Keyboard Replacement: step 7, image 2 of 2
      • Lift the battery out from the laptop.
      Ask FixBot
    1. Asus Q325U Keyboard Replacement, Copper Plate: step 8, image 1 of 2 Asus Q325U Keyboard Replacement, Copper Plate: step 8, image 2 of 2
      • Remove the six 3mm screws using a Phillips #00.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 9, image 1 of 2 Asus Q325U Keyboard Replacement: step 9, image 2 of 2
      • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
      Ask FixBot
    3. Asus Q325U Keyboard Replacement: step 10, image 1 of 2 Asus Q325U Keyboard Replacement: step 10, image 2 of 2
      • On the other side of the plate, remove the tape.
      Ask FixBot
    1. Asus Q325U Keyboard Replacement, CPU Fan: step 11, image 1 of 2 Asus Q325U Keyboard Replacement, CPU Fan: step 11, image 2 of 2
      • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 12, image 1 of 1
      • Detach the black wire and plug shown using a tweezer.
      Ask FixBot
    3. Asus Q325U Keyboard Replacement: step 13, image 1 of 1
      • Grab CPU fan by its edge and gently pull upwards to remove.
      Ask FixBot
    1. Asus Q325U Keyboard Replacement, Motherboard: step 14, image 1 of 2 Asus Q325U Keyboard Replacement, Motherboard: step 14, image 2 of 2
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 15, image 1 of 3 Asus Q325U Keyboard Replacement: step 15, image 2 of 3 Asus Q325U Keyboard Replacement: step 15, image 3 of 3
      Buy
      • Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
      • Remove the orange connector by pulling with tweezers.
      Ask FixBot
    3. Asus Q325U Keyboard Replacement: step 16, image 1 of 3 Asus Q325U Keyboard Replacement: step 16, image 2 of 3 Asus Q325U Keyboard Replacement: step 16, image 3 of 3
      • Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
      • Remove the touch pad connector by pulling with tweezers.
      Ask FixBot
    4. Asus Q325U Keyboard Replacement: step 17, image 1 of 3 Asus Q325U Keyboard Replacement: step 17, image 2 of 3 Asus Q325U Keyboard Replacement: step 17, image 3 of 3
      • Lift the black tab on the long white plastic piece of the thick blue band.
      • Remove the thick blue band by pulling.
      Ask FixBot
    5. Asus Q325U Keyboard Replacement: step 18, image 1 of 3 Asus Q325U Keyboard Replacement: step 18, image 2 of 3 Asus Q325U Keyboard Replacement: step 18, image 3 of 3
      • Remove the two Phillips #000 screws on the metal connector above the thick orange band.
      • Lift up the thick orange band.
      Ask FixBot
    6. Asus Q325U Keyboard Replacement: step 19, image 1 of 3 Asus Q325U Keyboard Replacement: step 19, image 2 of 3 Asus Q325U Keyboard Replacement: step 19, image 3 of 3
      • Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
      Ask FixBot
    7. Asus Q325U Keyboard Replacement: step 20, image 1 of 2 Asus Q325U Keyboard Replacement: step 20, image 2 of 2
      • Lift up the black hinge of the connector using a plastic opening tool.
      • Remove the connector using a tweezer.
      Ask FixBot
    8. Asus Q325U Keyboard Replacement: step 21, image 1 of 3 Asus Q325U Keyboard Replacement: step 21, image 2 of 3 Asus Q325U Keyboard Replacement: step 21, image 3 of 3
      • Pull up the tap of the biggest connector using your fingers.
      • Lift the gold hinge using a plastic opening tool.
      • Lift the connector up with your fingers to remove.
      Ask FixBot
    9. Asus Q325U Keyboard Replacement: step 22, image 1 of 2 Asus Q325U Keyboard Replacement: step 22, image 2 of 2
      • Remove the four 4.8 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    10. Asus Q325U Keyboard Replacement: step 23, image 1 of 2 Asus Q325U Keyboard Replacement: step 23, image 2 of 2
      • Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
      Ask FixBot
    11. Asus Q325U Keyboard Replacement: step 24, image 1 of 2 Asus Q325U Keyboard Replacement: step 24, image 2 of 2
      • Pull the motherboard away from the corner to remove.
      Ask FixBot
    1. Asus Q325U Keyboard Replacement, Keyboard: step 25, image 1 of 3 Asus Q325U Keyboard Replacement, Keyboard: step 25, image 2 of 3 Asus Q325U Keyboard Replacement, Keyboard: step 25, image 3 of 3
      • Remove the three 4 mm screws using a Phillips #00 screwdriver.
      • Remove the four 4.8 mm screws using a Phillips #000 screwdriver.
      Ask FixBot
    2. Asus Q325U Keyboard Replacement: step 26, image 1 of 1
      • Slide out the blue chip board connected to the long orange piece by gently grabbing the tab and lifting.
      Ask FixBot
    3. Asus Q325U Keyboard Replacement: step 27, image 1 of 1
      • Release the single MB wire by removing the black piece of tape.
      Ask FixBot
    4. Asus Q325U Keyboard Replacement: step 28, image 1 of 1
      • Untape the blue striped strip by pulling upwards and laying it flat.
      Ask FixBot
    5. Asus Q325U Keyboard Replacement: step 29, image 1 of 3 Asus Q325U Keyboard Replacement: step 29, image 2 of 3 Asus Q325U Keyboard Replacement: step 29, image 3 of 3
      • Starting at the upper left corner, remove the black adhesive from the keyboard.
      Ask FixBot
    6. Asus Q325U Keyboard Replacement: step 30, image 1 of 2 Asus Q325U Keyboard Replacement: step 30, image 2 of 2
      • Remove eighty 1 mm screws located on the keyboard frame using a Phillips #000 screwdriver.
      Ask FixBot
    7. Asus Q325U Keyboard Replacement: step 31, image 1 of 1
      • Grab the edge of the keyboard and lift upwards to remove.
      Ask FixBot
Author
with
Matthew Slawson
271 Reputation
2 Guides authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 55
All Time: 1,200
