Asus Q325U CPU Fan Replacement
    1. Asus Q325U CPU Fan Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U CPU Fan Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U CPU Fan Replacement, Back Panel: step 1, image 3 of 3
      • Remove the ten 5mm screws using a T5 Torx screwdriver.
      Ask FixBot
    2. Asus Q325U CPU Fan Replacement: step 2, image 1 of 3 Asus Q325U CPU Fan Replacement: step 2, image 2 of 3 Asus Q325U CPU Fan Replacement: step 2, image 3 of 3
      • Lift the back panel upward using the suction tool.
      Ask FixBot
    1. Asus Q325U CPU Fan Replacement, Copper Plate: step 3, image 1 of 2 Asus Q325U CPU Fan Replacement, Copper Plate: step 3, image 2 of 2
      • Remove the six 3mm screws using a Phillips #00.
      Ask FixBot
    2. Asus Q325U CPU Fan Replacement: step 4, image 1 of 2 Asus Q325U CPU Fan Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
      Ask FixBot
    3. Asus Q325U CPU Fan Replacement: step 5, image 1 of 2 Asus Q325U CPU Fan Replacement: step 5, image 2 of 2
      • On the other side of the plate, remove the tape.
      Ask FixBot
    1. Asus Q325U CPU Fan Replacement, CPU Fan: step 6, image 1 of 2 Asus Q325U CPU Fan Replacement, CPU Fan: step 6, image 2 of 2
      • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Asus Q325U CPU Fan Replacement: step 7, image 1 of 1
      • Detach the black wire and plug shown using a tweezer.
      Ask FixBot
    3. Asus Q325U CPU Fan Replacement: step 8, image 1 of 1
      • Grab CPU fan by its edge and gently pull upwards to remove.
      Ask FixBot
2 other people completed this guide.
Matthew Slawson
271 Reputation
2 Guides authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 68
All Time: 1,217
