Asus Q325U Battery Replacement
    1. Asus Q325U Battery Replacement, Back Panel: step 1, image 1 of 3 Asus Q325U Battery Replacement, Back Panel: step 1, image 2 of 3 Asus Q325U Battery Replacement, Back Panel: step 1, image 3 of 3
      • Remove the ten 5mm screws using a T5 Torx screwdriver.
      Ask FixBot
    2. Asus Q325U Battery Replacement: step 2, image 1 of 3 Asus Q325U Battery Replacement: step 2, image 2 of 3 Asus Q325U Battery Replacement: step 2, image 3 of 3
      • Lift the back panel upward using the suction tool.
      Ask FixBot
    1. Asus Q325U Battery Replacement, Battery: step 3, image 1 of 2 Asus Q325U Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
      Ask FixBot
    2. Asus Q325U Battery Replacement: step 4, image 1 of 2 Asus Q325U Battery Replacement: step 4, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
      Ask FixBot
    3. Asus Q325U Battery Replacement: step 5, image 1 of 2 Asus Q325U Battery Replacement: step 5, image 2 of 2
      • Lift the battery out from the laptop.
      Ask FixBot
4 other people completed this guide.
Flo Costa
235 Reputation
1 Guide authored
Cal Poly, Team S19-G1, White Winter 2019 Member of Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
3 Members
72 Guides authored
7 Guide Comments
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Dan Goldman - Reply Share
Would recommend the screw size be ad to the guide please.
John Walshaw - Reply Share
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
Michelle N - Reply Share
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
Steve Kumar - Reply Share
the battery shown here is not the same for the Q325U, different battery connectors.
Joshua Delgado - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 92
All Time: 5,676
