Asus PadFone S Rear Facing Camera Replacement
    1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: step 1, image 1 of 2 Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: step 1, image 2 of 2
      • Place your thumb in the charging port and pry the back cover off of the phone.
      • Separate cover all the way around the sides of the phone.
      Ask FixBot
    2. Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: step 2, image 1 of 2 Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: step 2, image 2 of 2
      • Remove all the screws on the back panel using a T5 Torx screwdriver.
      • Lift the back panel off to reveal the logic board and battery.
      Ask FixBot
    3. Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: step 3, image 1 of 3 Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: step 3, image 2 of 3 Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • The back camera is located at the top left on the logic board.
      • Use tweezers to lift back camera strip from logic board.
      • Lift back camera out of logic board.
      • It is not necessary to remove logic board for removal of the back camera.
      Ask FixBot
Christian Trippe
79 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 39
All Time: 1,687
