Asus PadFone S Front Facing Camera Replacement
    1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: step 1, image 1 of 1
      • Place your thumb in the charging port and pry the back cover off of the phone.
      Ask FixBot
    2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: step 2, image 1 of 2 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: step 2, image 2 of 2
      • Remove all screws using the T5 Torx screwdriver
      • Lift the back panel off the phone.
      Ask FixBot
    3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: step 3, image 1 of 2 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the battery from the logic board using tweezers
      • Using the plastic opening tools, lift the battery up from its slot
      • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
      Ask FixBot
    1. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: step 4, image 1 of 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: step 4, image 2 of 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: step 4, image 3 of 3
      • Once the Battery has been successfully removed, move on to the step 2.
      Ask FixBot
    2. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: step 5, image 1 of 2 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: step 5, image 2 of 2
      Buy
      • Disconnect the marked strips from the logic board using the tweezers.
      • Applying too much force may damage the strips/connectors.
      • Remember to remove speaker connection located at the bottom left hand corner.
      Ask FixBot
    3. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: step 6, image 1 of 2 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: step 6, image 2 of 2
      • Disconnect the other two strips that connect the logic board to the phone.
      Ask FixBot
    4. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: step 7, image 1 of 2 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: step 7, image 2 of 2
      • Turn over the logic board to locate the front camera.
      • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
      • Applying to much force will damage the connective strip.
      Ask FixBot
Everette Gonsalves
26 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 27
All Time: 1,897
