Up to 20% off select tools
Asus PadFone S Battery Replacement
Views: 9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
19
Past 30 Days:
101
All Time:
8,957
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the battery of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. The battery will be difficult to remove so make sure you follow the directions carefully.
    1. Asus PadFone S Battery  Replacement, Remove the Back Panel: step 1, image 1 of 1
      • Place your thumb in the charging port and pry the back cover off of the phone.
      Ask FixBot
    2. Asus PadFone S Battery  Replacement, Remove the Back Panel: step 2, image 1 of 2 Asus PadFone S Battery  Replacement, Remove the Back Panel: step 2, image 2 of 2
      • Remove all screws using the T5 Torx screwdriver
      • Lift the back panel off the phone.
      Ask FixBot
    3. Asus PadFone S Battery  Replacement, Remove the Battery: step 3, image 1 of 2 Asus PadFone S Battery  Replacement, Remove the Battery: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the battery from the logic board using tweezers
      • Using the plastic opening tools, lift the battery up from its slot
      • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
      Ask FixBot
Author
with
Greg Betsold
96 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 19
Past 30 Days: 101
All Time: 8,957
